audi wheels on a W209?
Subscribe
Nov 11, 2008 | 01:14 AM
will wheels made to fit an 2005 Audi S4 fit on a W209? I know the bolt pattern and offsets will work, but what about the hub? Will I need hub rings? Thanks. Tommy
Reply 0
Nov 11, 2008 | 05:14 PM
honestly why would you want to do that.....
Reply 0
Nov 11, 2008 | 05:32 PM
seriously, don't you think audi stock rims are UGLY?????
Reply 0
Nov 11, 2008 | 05:49 PM
Quote: will wheels made to fit an 2005 Audi S4 fit on a W209? I know the bolt pattern and offsets will work, but what about the hub? Will I need hub rings? Thanks. Tommy
it's the other way around.....
Mercedes wheels can fit on Audi w/ hub rings : (66.6 to 57.1) Audi rims will not fit on Mercedes Hub's unless you get them drilled out from 57.1mm to 66.6mm.
Reply 0
Nov 11, 2008 | 07:48 PM
it is not that audi rims are ugly or better than MB rims i just never really understood why someone would want rims that have audi logos on their mb or vice versa. i sort of get the audi wheels on vw or porsche wheels on either because they are all from the same family. maybe i am nuts
Reply 0
Nov 11, 2008 | 09:09 PM
Its not the stock wheels. I had a set of 19x8.5 HRE 540R's on the S4 and I wanted to use them on the CLK.
Reply 0
Nov 11, 2008 | 09:13 PM
Quote: Its not the stock wheels. I had a set of 19x8.5 HRE 540R's on the S4 and I wanted to use them on the CLK.
You'll have to get the hub bore'd out for them to fit on the clk.
Reply 0
Nov 12, 2008 | 03:49 PM
i gotcha my bad. the offset, backspacing, and bore on MB's are really odd. i think they just got worse on the new C Class as well. if i am not mistaken the offset is over 50 now.
Reply 0
Explore
Feb 24, 2011 | 10:51 PM
how much would it cost to bore out a hub? anyone konw?
Reply 0
Feb 24, 2011 | 11:54 PM
Quote: seriously, don't you think audi stock rims are UGLY?????
i think the RS4 wheels are really nice, but the OP never said they were stock Audi wheels
Reply 0
Feb 25, 2011 | 10:19 AM
It's like seeing VW's, and Audi's on AMG monoblocks. For whatever reason it's the thing to do right now. If you ever wanna sell yours, post them on a VWVortex. They'll go quick.
Reply 0
Feb 25, 2011 | 11:52 AM
I believe that newer Audis used 66.6mm centre bore. If the offsets are suitable, the wheel should fit. Otherwise, perhaps you can use spacers to play with the offsets.
Reply 0
Feb 26, 2011 | 05:14 AM
If it is like whats in the OPs sig, they look badass!!
Reply 0
Subscribe
Currently Active Users (1)
