Muffler for CLK55 W208
Old Nov 20, 2008 | 11:44 AM
Green CLK55's Avatar
2001 CLK55 AMG - '91 Ferrari 348tb - '05 Viper SRT10 - 72 Porsche 911E - 74 Porsche 914 - 67 Cougar
I want a deeper, throatier sound from my CLK55. Perhaps even a little loader too. Can I install Dynoflow of similar that you'd find on an American car? Will I be able to keep AMG tips?
Old Nov 20, 2008 | 12:04 PM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
You can put magnaflow mufflers and get a better sound. I'd cut the resonator if I were you. That should do the trick. Don't even have to buy a muffler. Just replace it w/ piping and a y pipe. Should cost under $150. It cost me about $90. I also have a high flow muffler, but that makes it even louder.
Old Nov 24, 2008 | 10:10 AM
I have yet to put it up on my garage hoist. Is there cats that can be cut out too? I live in Albetra where there is no exhaust testing.
Old Nov 26, 2008 | 12:50 AM
I killed the 2nd cats (by the resonator, center of the car) and the resonator and replaced it w/ 2.5" straights...no CEL issues so far (2 wks). The o2 sensors are before the 2ndary cats
Old Nov 26, 2008 | 01:41 AM
fredyfunk's Avatar
CLK 55 AMG
Just wondering, what does removing the 2nd cats achieve? Does removing just the resonator give it a good sound?
also, would removing the resonator mess up anything? would it still be able to pass a smog check? etc?
Old Nov 27, 2008 | 02:44 AM
cats are for power due to flow losses in the cat (maybe a little weight too). probably minimal. the resonator is just for sound and weight and will not cause smog/emissions problems
Old Dec 11, 2008 | 01:18 PM
Has any check engine lights come on? I'm gonna cut out secondary cats and resinators and will hopefully unleash some sound and performance.
Old Dec 11, 2008 | 01:33 PM
wideclk's Avatar
wideclk
you can remove the secondary cats and resonator and muffler and there will be no CEL.
Old Dec 12, 2008 | 05:23 PM
Boosted9603's Avatar
CLK55 AMG
Yeah, use a Magnaflow muffler and take out the secondary cats. It makes it sound much better than factory!
Old Dec 12, 2008 | 06:06 PM
hhseouljah's Avatar
2001 CLK 55
i've removed my secondary cats and resonator, not that much of a increase in sound while driving around, but sounds pretty good at WOT. if you want loud, put on that magnaflow, if you want extra loud, just straight pipe it from the o2 sensors back.
im planning on just putting on an electronic cutout so that i can have 2 options of sound level. =D
Old Dec 13, 2008 | 11:34 AM
No check engine light issues at all. Removing the secondary cats, resonator, and eisenmann race make an exciting combination!
Old Jan 26, 2009 | 07:32 PM
BenzManAMG's Avatar
2004 CLK 55 AMG
Took my W209 CLK 55 to the muffler shop today and they said I dont have a resonator on my car model??? They said I just had a muffler. Not to ask a stupid question or anything, but where is the resonator on this model if there is one because I thought all mercedes had resonators?
Old Jan 27, 2009 | 12:06 AM
SoCalCLK's Avatar
2017 W205 C43 AMG
Good point. I think W209 CLK55's do not have resonators, but the OP's asking about W208 CLK55's which still do, I believe.
I would recommend: 1) Cut the resonators and drive it around for 100 miles. See if you like the sounds and performance. 2) If that doesn't do it, then take out the cats if you want and that way you know the difference between the two steps.
Old Jun 12, 2009 | 10:42 AM
drwavedawg's Avatar
which magnaflow do you guys suggest? doesn't the clk55 have a 70mm inlet muffler? magnaflow doesn't make anything with that size inlet...
