2005 CLK55 AMG WITH SL55 BRAKES?
Old Dec 28, 2008 | 12:28 PM
zthis's Avatar
04 SL55 AND 05 CLK55
Just bought a 2005 clk55 in rare Orion Blue and I'm going to keep this one! I rolled my SL55 and before they hall it away(have a week)I wanted to know if the larger brakes, f&r would fit? I haven't checked yet on the wheels but I'm hoping my stock 18" multi spokes will fit at least. Any help on this matter would greatly be appreciated! I was also wondering about the airbox. Is it like the E55, could I make it work? Insurance company ripped me on my cars value so I'm trying to get the most of it.
Old Dec 28, 2008 | 01:32 PM
sick430's Avatar
CLK Cabrio
yes the air box will fit. as should the bigger brakes. the air box will also give you a nice performance gain as well.
Old Dec 28, 2008 | 01:33 PM
sick430's Avatar
CLK Cabrio
you will need to pull the y tube as well
Old Dec 28, 2008 | 03:11 PM
zthis's Avatar
Thanks a bunch guys! What about drop in filter panel replacements? Any recommend brands besides k&n? On the airbox, is there any customizing or is it a bolt up install?
Old Dec 28, 2008 | 06:36 PM
M-bENZ's Avatar
Corrolla
Green Filter
Old Dec 28, 2008 | 06:58 PM
sick430's Avatar
CLK Cabrio
go green!!!!
as for the air box just remove the entire unit from the SL including the "Y" splitter and install it onto the CLK. there are just clips so it should not be difficult
Old Dec 28, 2008 | 07:13 PM
zthis's Avatar
Thanks again. I will post pics when all is done.
Old Dec 31, 2008 | 02:10 PM
spr's Avatar
spr
you'd have to pull the spindles to have them work- different bolt pattern etc.
Old Jan 1, 2009 | 03:28 PM
zthis's Avatar
Bolt pattern is the same for the wheels. Do you mean the bolts and nuts configuration mechanically?
Old Jan 2, 2009 | 12:10 PM
spr's Avatar
spr
calipers.
Old Jan 2, 2009 | 03:22 PM
zthis's Avatar
I see, thanks for the heads up. So it can be done and you're saying I would have to switch the complete spindle? Is that possible? I'm assuming you have done this or read of this swap. Thanks again for the info.
Old Jan 3, 2009 | 06:41 AM
KIWI KEN's Avatar
CLK63, CLK 55 kleemann, Nissan GTR N1
As for the brake conversion. i am currently fitting CL55K brakes to my CLK. I do not have CL55 spindles and do not know whether they will fit while maintaining the correct dimensions.
The CL/ SL brake rotors are larger in diameter and thickness also having a different offset.
I am having custom rotors and adapter blocks for the CL calipers made to suit the CLK.
