CLK55 caliper W209
Old Feb 19, 2009 | 02:18 PM
mikare's Avatar
CLK 350
CLK55 caliper W209
Can I put the CLK55 AMG's cpliper on my CLK350?
What do I need to make it done? I have asked my dealer, but they are not sure about that.
Thanks!
Old Feb 20, 2009 | 07:47 AM
Stiggs's Avatar
2003 CLK55
I guess the biggest problem would be if the caliper would clear the rim? I would say the brakes definitely fit, but you might need to get new rims?
Old Feb 20, 2009 | 02:13 PM
mikare's Avatar
CLK 350
Thanks!
How about the 03 or 04 CLK55 AMG 4-piston Caliper?
Can it clear my 17 inch wheel?
Old Feb 23, 2009 | 11:58 PM
coin's Avatar
'06 CLK500
Originally Posted by mikare
Thanks!
4 piston calipers will clear your OEM 17" for sure
Old Mar 4, 2009 | 03:45 AM
TTAMG's Avatar
2011 C63
other then wheels you need pads wear sensor and rotors. That is if you are going to upgrade to the brembo oem stuff.
Old Mar 15, 2009 | 01:12 PM
fredbaum's Avatar
CLS 55 AMG - one of the last off the AMG line
quick question - my rear tire's callipers on the CLK55 (2004 model year) arent AMG branded - did someone take them out - or did the 03-04 just have AMG branded front callipers ?
Old Mar 15, 2009 | 09:29 PM
HCUBED's Avatar
W209 2003 CLK55 Coupe
OEM brake calipers
Since the majority of braking power on all cars is on the front wheels, the factory CLK rear brake calipers are standard equipment on the CLK55 AMG.
The AMG caliper is only used on the front.
Old Mar 16, 2009 | 07:30 AM
fredbaum's Avatar
I understand - thanks - what didnt make sense to me was why I have seen a couple of other CLK55's with AMG branded callipers - is there a rear option as well ? Particularly it was a cabriolet I saw last - and judging by the lack of dual right and left exhaust I figure it was a 2003-2004 model.
Old Mar 16, 2009 | 07:53 AM
mikare's Avatar
CLK 350
The rear rotor for the CLK350 is solid disc not the ventilated disc.
I know the 09 CLK550 is the ventilated disc on the rear and it is bigger then mine.
Old Apr 27, 2009 | 11:50 PM
noco-marc's Avatar
clk 55 cabrio
rear brakes clk 55
I had the same question myself and wonder if anyone can provide a definitive answer? My '04 clk 55 cabrio has solid rear discs w/o amg calipers, yet I saw another clk 55 cabrio today with drilled and slotted rotors.
Old Apr 28, 2009 | 12:14 AM
M-bENZ's Avatar
Corrolla
They are probably from 06.
Old Apr 28, 2009 | 12:23 AM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
there's a related thread in the w209 forum.
