oil change $
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
oil change $
How much did you pay for your oil change?
I just went to my MB dealer and they charge me 200$![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Normal for a 55 NA ? it's like 8 bottle of Mobil 1 0W40
94$ for oil
64$ for checking the general engine ( I guess it's 64$ for sleeping)
24$ for a special extended life oil filter
+ Tx
= 200$
Is that right?
94$ for oil
+ Tx
= 200$
Is that right?
man jsut do it yourself its not hard if u dont wana get under the car get one of those fluid evacuator is only $75 then u can buy your oil anywhere you want and the filter too.
Andy
Andy
i believe about 130 is standard rate. looks like you got cut a little extra my friend.
I change my own and the oil costs about $40 and the MB oil filter is about $20.
94$ for oil
+ Tx
= 200$
Is that right?
94$ for oil
+ Tx
= 200$
Is that right?
2005 CLK55 AMG CABRIOLET
there is a post on another MB forum on how to do a DIY oil change.
my dealer charges $125 for it. so i started doing it myself.
what u need:
mobil 1 synthetic (or equivalent) 9 quarts
oil filter cartridge (i recommend the better fleece type vs. cheaper paper type) - the filter comes with the o-rings
oil cap removal tool (can get at walmart - just need the right size one)
oil extractor (i recommend - no need for ramps/jacks etc. much safer) - i bought the motive power extractor from amazon
1. warm up car for about 5 minutes
2. shut off car
3. remove oil filter cap and oil filler cap
4. remove shaft containing oil filter (Place aside for now)
5. remove red cap covering oil dipstick tube
6. insert line from power extractor until it reaches bottom
7. prime extractor and start it
8. back to filter - remove filter and o-rings from shaft
9. install new filter and o-rings on shaft (note sizes of o-rings)
10. after extraction is complete remove tubing
11. replace red cap on dipstick tube
12. reinstall oil filter shaft
13. note volume of oil removed on extractor and add same amount back to engine
14. replace oil filler cap
15. start engine and run for a few minutes
16. check oil level
17. reset FSS
you are done. parts will cost you about $70 per oil change saving for $50 each time.
what u need:
2. shut off car
16. check oil level
17. reset FSS
what u need:
2. shut off car
16. check oil level
17. reset FSS
what u need:
2. shut off car
16. check oil level
17. reset FSS
02 CLK 55 AMG,09 C63 loaded with P30
I don't know about the w209 Clk55 but the w208 Clk55 self oil change is the easiest to do. Filter is right on top under the hood. I use ramps to get under.
you can do it either way. i have done both. but if you try extracting it, you'll never go back to draining.
1. no need for ramps (Crawling on ground)
2. no need to get under car (safety issues)
3. extracting gets out just as much oil (i know there are doubters, but try it and you'll see for yourself)
4. a lot less mess (No oil splash at all)
5. the one con is it does take a bit longer
Use the pump
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
takes minutes.
Filter at autohausaz.com for about 11 bucks,proper fleece.
MB1 0-40 syn if you join the mobil web club they have coupons for 10 bucks off 5 qts.
Diy of the proper evacuation method for any M112 and M113(yours) engine is on www.mercedesshop.com
resource section diy articles.
200 bucks?wait till you see what they will charge you for a spark plug change
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
takes minutes.
Andy
I went to Las Vegas, and stopped by Fletcher Jones MBZ for an oil change, and they replaced the air filter elements, changed the oil and filter using Mobil 1, and only charged me $112.34. This price included the filters, oil and labor!!! (milage at that time was only 31,079..."B" Service)
When the service advisor went to the rear of the car to write down the license number, he noticed that I was driving an AMG and moved me to the front of the line!!
I like this dealership!
Andy
Omg.... I feel like I got ripped off.....
