Help with CLK Clock
If the clock doesn’t display, you’ll need to fix that before worrying about setting the time. Dropped pixels are a well known issue. This is a link where the fix for that problem is discussed:
https://mbworld.org/forums/clk-class-w208/241804-diy-lcd-repair-odometer-clock-temp-etc.html
If that doesn’t work, BBA can rebuild them
http://www.bba-reman.com/uk/index.aspx
or the dealer can sell you a new one.
This is how you set a clock:
https://mbworld.org/forums/1575485-post33.html
