More exhaust note
#76
The initial pipe before the primary cat is ~2.0" OD (by #30). After the primary pipes its 2.35" OD pipe all the way back until it becomes a single pipe then it becomes larger at the Y-pipe. For the cats you can get 2.5" cats and slide them over the piping that should do the job just fine.
hope that helps.
hope that helps.
#77
hope that helps.
hope that helps.
Tony,
not try to hijack your thread hope you dont mind....
Andy
#80
As long as you use 300-cell metal core cats and you make sure the welds are strong and there are no leaks, then they should not cause a CEL. 200-cell or lower and you start getting too close to the threshold. With that said there is a decent amount of power to be picked up by the primaries as well (more so than the secondaries) which is where majority of the power comes from on medium/long tube headers that delete primary cats.
#81
thx for the info AMS, im gonna go through with changing out both cats.. i just wanna be sure before i buy them tonight.. i have an 03, which has the single sided dual exhaust unlike the 05s which have dual sided quad exhausts.. do i have two cats while the 05s have four? or do i have four also? im a noob when it comes to MB, just got my car a couple months ago.. thanks for the knowledge
#82
#86
#87
i have a 209, but just probably? im gettin my paycheck today and was planning on ordering these cats tonight.. i wanna be 100% sure these are gonna fit..
#88
hope that helps.
#90
#91
Andy
#95
I've now installed the RT or Magnum 300 cell highflow cats recommended by AMS in the seconday position. Sound is a little louder, not much. They seem to work just fine and the car, per the butt dyno, shows huge improvement in acceleration going from 55 to 110. I will dyno after my intake mods are finished and installed.
#96
Andy
#98
Tump,
After a few weeks the sound should develop even more, it takes some time for 2nd cats to really break in and the ECU to adjust, once it does the sound should be deeper & meaner.
#99
recommended seconary cats ??
Has anyone used a specific cat and gotten significant Hp gains ?? I guess what I am really asking is if you have link to order these ?? I have clk500 06'
