NEW HELP, HELP PLEASE!
Old Nov 29, 2009 | 07:51 PM
5o2's Avatar
5o2
Mercedes CLK 55 AMG
On my 2002 clk 55 on my dash both of mine right conor thingy went out. where it tells the time and what gear your in.(P,R,D) and the one that says the tempure outside. CAN I REPLACE JUST THOSE TWO OR DO I HAVE TO REPLACE THE WHOLE GAGUES?
THE one ON LEFT AND RIGHT.
Old Nov 29, 2009 | 09:29 PM
cindyclk's Avatar
https://mbworld.org/forums/clk-class...-temp-etc.html
or $200 at http://www.bba-reman.com/catalogue/D...ledProduct=556
Old Nov 30, 2009 | 02:55 AM
joeljp's Avatar
2012 C63
It's a very common problem with W208. From what I gathered, it all stems from poor contact with the ribbon like cable. Mine was just started to play up with the "gear" display missing a couple of pixels. I pretty much just removed mine from the dash, simply grab and pull the unit out, and push in back in and it fixed the problem. However, there a lots of very well detailed explaination on how to actually reseat and tighten the contact points. You'll find the posts if you were to poke around the W208 section of the forum. The DIY tricks certainly have worked for many on here, hope it works for you.
Good luck!
