i have found a set of oem E63 wheels online...my question is will they fit properly? are they a direct bolt on? any info? thanks guys
I'm sure they are a direct bolt-on but not sure if they will fit. Your going to need to find out the ET
you will not have any fitment issues. I have a set on my car, the hard part is finding the bolts to fit. I found a set at pep boys that worked
good luck
good luck
Quote:
good luck
so the offset and everything work perfect? no spacer or anything ?Originally Posted by hami
you will not have any fitment issues. I have a set on my car, the hard part is finding the bolts to fit. I found a set at pep boys that workedgood luck
Andy
Quote:
Andy
not at all my only problem was that the bolts werent the right size and that wasnt a major problemOriginally Posted by M-bENZ
so the offset and everything work perfect? no spacer or anything ?Andy
i've had them on for over a year now with no problems
what are the offsets? are the wheels flush with the fender? or do they bow out? thats the last thing i want is for them to have the lowrider stance!!
they have he same offset and fitments as the stock rims
so it looks natural
so it looks natural
ExploreMBWorld Fanatic!
I'm possibly buying these rims off of fitness guru and my question is whether or not they'll fit my CLK550, preferably without spacers.
The offsets are 38(18x8.5) in the front and 39(18x9) in the rear.
Worried about the brake clearance.
Finding the right bolts will be the main issue. Spacers are nice but not a must have for fitment
Quote:
How can you say that? If they don't clear my brakes, then I would NEED spacers.Originally Posted by SoCalCLK
I have a set of longer bolts that I can cut down to make fit, so I'm not as worried about that.
How do u know u will have to cut them down instead of making longer ? Originally Posted by kevblah
How can you say that? If they don't clear my brakes, then I would NEED spacers.I have a set of longer bolts that I can cut down to make fit, so I'm not as worried about that.
Andy
Quote:
Andy
That's a good question.Originally Posted by M-bENZ
How do u know u will have to cut them down instead of making longer ? Andy
I have 50mm lugs that I used on my S55/CL55 rims that had an offset of 44 all around and 10mm spacers all around, so an effective offset of 34. If the 50mm lugs are too short, the perfect size would fall somewhere in between 50mm and 55mm, so I would just buy a set of 55mm lugs off eBay, I suppose.
I can say that from personal experience. I had a set of E55 wheels on my CLK55 without spacers, but with the right bolts, and they fit.Originally Posted by kevblah
I would not recommend "cutting bolts", we're not in high school, for goodness sakes.
Well, I got the wheels last week and they hit the front strut without spacers, so I'm running a 5mm in the front now and a 10mm in the rear.Originally Posted by SoCalCLK
I can say that from personal experience. I had a set of E55 wheels on my CLK55 without spacers, but with the right bolts, and they fit.I would not recommend "cutting bolts", we're not in high school, for goodness sakes.
