Cabriolet soft top closing 99% of the way - but no "ding"
I went to put the top up just now and it got all the way to the end of the cycle - where the front end flops down and is ready to be pulled down and shut by the handle - and it just ... stopped.
No "ding" as I expected. No red light on the switch going off. If I continue to hold the switch down, it just starts to flash red. I tried to open the trunk and it wouldn't let me. (No, the trunk wasn't ajar.)
So I put the top back down and it did "ding" at the end of that cycle, and I was able to open the trunk. But when I tried to put the top back up ... same thing. No "ding", no cycle completion. I am able to pull the hood down and twist it into the shut position ... but why the heck is it stopping at the 99% mark?!?
Which to me means it's probably dangerous to drive in that state - right?
Not sure what you mean by "pull the inside cover and inspect" - inside cover of ... ?
Mercury (Extended Warrantee) is coming out to check it out tomorrow ... sure hope they cover that one.
Other things found ... ball joints bad (creaking noise front left) ... lifters possibly bad and making noise (apparently driving 15,000 miles in 8+ years isn't often enough
) - but Mercury will also look at that too. $400 just to open the thing up and get at the valves and lifters to have a look
Starting to get the idea that after my extended warrantee runs out (in early 2011) it might be time to let the ol' gal go
Yes the control switch (or whatever it was) replacement did the trick ... my top is back happily locking properly with "ding".
Unfortunately the stealership was not so good when it came to my front left end creaking noise ... they replaced the ball joints and the engine mounts (supposedly) and it's still creaking like crazy
To make matters worse after they finished with it now I have a brand-new noise ... sounds like it's coming from the actual hood itself, it's almost like a rapid click/dripping sound when in motion (doesn't happen when at idle). Grrrr ...
2 months left 'til the extended warranty runs out. Hmmn ...
