E55 amg to clk 55 cylinder head interchange??
What year range is the 210? The 211? And what problem may I run into using a 211?
Thanx a bunch
however I do have one more question: would a set of heads off of a 2005 clk 55 amg still have the same benefits as the 2005 e55 amg heads?
Kinda hard to tell but it appears the number on one of the heads reads R 113 016 07 01. Need quick responses. Ty all.
l
While doing the port work, the dual springs may be a simple upgrade. You already have the outer springs. The inners cost about $325 for a set. You’ll need the bottom retainers. Those are about another $125. However, if you’re not swapping cams for something with more lift, and there is no evidence of float, there may not be an upside.
From the way pte worded it; it sounds like all 5.5 heads from 05+ have that design improvement. Can anyone(including pte) confirm or deny that or are the improved exhaust ports just a s/c 5.5 thing?
