fuel injector compatability 03 sl500 - 01 clk 55 amg
You might call a Mb parts dept and ask if the part numbers are the same.
Why not have them rebuilt? Most big cities have injector shops.
It's a not-so-clever design to discourage people from re-using parts. I just need to know if the flow rates are the same or not so I can decide whether to stockpile the Injectors(off of a used intake Assy I bought) or sell them cheap.
Also, some times the parts clerk will give callers standard answers because they don't want to deal with people who they feel are simply calling for info. This isn't limited to MB. I know of one SoCal Porsche dealer who refused to cross reference parts unless you were buying them from him.
- The fuel injector for a 2001-2002 CLK55 is Mercedes-Benz part number 1130780149.
- The fuel injector for a 2003-2006 CLK55 is Mercedes-Benz part number 1130780349 (the dealer will show it as the same part used in a 2001-2006 CL55, which is boosted).
- The fuel injector for a 2003-2006 SL500 is Mercedes-Benz part number 1130780249.
0280156016 is a BOSCH part number, not a Mercedes-Benz part number. Bosch builds the parts, but they use a very different numbering system. The Bosch number you listed is for a 14.5 ohm injector that flows 206 cc’s per minute at 3 bar (19.619 lbs/hr). Why do I know so much about those particular injectors? Those are the stock injectors for my CLK430.
The stock CLK55 injector is a Bosch part number 0280156075. I have no idea what it flows. I have never seen an AMG spec Bosch injector on a Bosch injector spec sheet.
