Clock on CLK 55 AMG
Old May 24, 2011 | 12:43 AM
tagcab's Avatar
CLK 55 AMG
Clock on CLK 55 AMG
I have read both manuals, everything on this site and I still can't set the clock left of the speedo. I set the Nav clock no problem but there is no link to the dash clock??? There is no option to set time in the dash cluster. Not sure if i have to take it in or am I missing something? Help if you can!
Old May 24, 2011 | 01:07 AM
Moedy's Avatar
'05 CLK55, '04 CLK320
thats weird my dash clock changes when I do it on the command. what year car?
Old May 24, 2011 | 07:25 AM
lsboogy's Avatar
2002 CLK55, 1993 190E, 1975 230C, 2007 E350
owners manual
http://pdfservicemanual.com/automoti...-owners-manual
Check page 111 in the thing
Old May 24, 2011 | 07:27 PM
tagcab's Avatar
CLK 55 AMG
2005
Old May 25, 2011 | 01:09 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Yup.......mine too an it a 2006 model.
Old May 25, 2011 | 09:03 AM
cindyclk's Avatar
The clock should set automatically based on the time zone that you enter/ also daylight savings time. The time zone will override the manual time that you enter. I have a european command unit and I have to set my command to Russian Federation East Serbia to get to Eastern Standard time (12 hours behind). The dash clock automatically will be the time zone time.
Old Aug 13, 2011 | 07:20 PM
purplebubble's Avatar
mercedes e320
i have a mercedes e320 (2000) and again i have also read both manuals and I still can't set the clock on the dash.
I again can set the sat Nav clock but is there a way to transmit this time to the dashboard? as i have COMAND there is no option to set the time in the dash cluster.
can anyone help please?
on a separate note i cannot lock or unlock the back two doors with my key however the front two work perfectly.
the key whiel locking will close the windows (even the back ones as well as the sunroof) but it just wont lock or unlock the two door at the back.
any help/ advice would be much appreciated!
thank you
Old Aug 15, 2011 | 07:52 AM
cindyclk's Avatar
Changing the "time" on the command will not change the dash. You must set the correct time zone and country/daylight savings/or not. It is that setting that will change the clock. The time comes from "above" not what you set it...similar to the time on your cell phone.
