Weird noise when Turning
Old Jan 15, 2012 | 10:59 AM
njgilligan's Avatar
2001 CLK55
I was pulling out of a parking spot this morning and I had the wheel turned to the right, almost all the way, and I heard a strange 'popping' sound, seemingly coming from the front right wheel. It sounded as if the wheel was plucking the coils of the spring like a guitar spring. It was pretty cold, ~8deg F, but I'm not sure if that had anything to do with it. I have stock wheels and tires (17x7.5 225 45 17). I had the car jacked up last week, and checked ball joints, and everything seems tight.
BTW, I'm looking for some info here before I venture outside where it's still sub 10 degrees, so I haven't been under the car since I heard the sound.
Old Jan 15, 2012 | 12:56 PM
whtclk's Avatar
CLK550
im thinking it was just because the coil was cold but if it continues to happen when its warm then i would put some coilover lube on the threads to stop this
Old Jan 15, 2012 | 04:16 PM
MarcusF's Avatar
2002 CLK430
Have the steering gear bolts been serviced in the past 4 years or 50,000 miles? This link will explain the procedure. The service is very simple, takes little time to perform.
Old Jan 15, 2012 | 06:22 PM
lsboogy's Avatar
2002 CLK55, 1993 190E, 1975 230C, 2007 E350
Marcus is great
I did this last summer after getting a service manual - took care of a slight noise when turning - Marcus is a great resource - thanks again my friend for everything you do for all of us
Old Jan 15, 2012 | 06:37 PM
cindyclk's Avatar
I don't think that it a thing to worry about. I have used PS2s on both my 430 and 55...both have had that same sound when turning the wheel at very slow speed. They grip so well that when you are turning the wheel faster than it can track at the slow speed, it simply pops into line. It is even more evident in parking garages where they have coated the concrete w/whatever.
Old Jan 15, 2012 | 06:49 PM
njgilligan's Avatar
2001 CLK55
I actually re-torqued the steering gear bolts last week (thanks for the instructions). I can feel the vibration in the steering wheel when I hear the noise. I wonder if I may have over-torqued and snapped one of the bolts...
Old Jan 15, 2012 | 07:03 PM
AMGJared's Avatar
09 335i 03 CLK55 AMG
Haha when I saw the title from the main page I was like oh this is easy power steering fluid then I read your thread and I was like oh...ok...next post...hehe. Hope you figure it out.
Old Jan 15, 2012 | 07:20 PM
njgilligan's Avatar
2001 CLK55
That seems to make sense. I might try having someone turn the wheel so I can see it. I'm glad my tires are plenty sticky.
Old Jan 15, 2012 | 09:57 PM
MarcusF's Avatar
2002 CLK430
Glad to be of help.
