CLK 55 amg rotors size
Old Jan 18, 2012 | 06:52 AM
ruisilva's Avatar
S2000
Hi Guys..
My CLK 55 has the upgrade of brakes, 6 pot on the front.
I have one doubt, the size of discs doesnt change with the upgrade?
All CLK55 W209 has the same size? or not?
I`m always watching sellers publishing Rotors for CLK55 2003/2004.
So it doenst fit on my CLK55 facelift?
Cheers and thanks for Help
Old Jan 18, 2012 | 11:13 AM
ambit's Avatar
09 CLK550
14.1" I think?
Old Jan 18, 2012 | 03:01 PM
ruisilva's Avatar
S2000
Originally Posted by ambit
14.1" I think?
Thanks a lot... yes 14.1IN = +- 358mm.
So 360mm is my answer.
Best regards
Old Jan 20, 2012 | 12:52 AM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
03-04 CLK55 rotors are smaller.
Old Jan 21, 2012 | 03:52 AM
BRIZZOK84's Avatar
2003 CLK55AMG
Did your car some with that size brakes or did you put a different kit on it???
Old Jan 21, 2012 | 04:37 AM
ruisilva's Avatar
S2000
My brakes are Stock.
After facelift of CLK, around 2005 i think it start come with these brakes.
Its similar to the CLK63 i think.
In 2003/2004 the size are 340mm and 4pots in the front.
Old Jan 26, 2012 | 02:01 PM
Johawk79's Avatar
2001 CLK 55 AMG
2001 - 2002 (The part numbers are different from side to side, but the dimensions are the same, obviously)
2003 - 2004
2005-2006
2007 - 2008 CLK63
Old Jan 26, 2012 | 11:06 PM
NardoNZ's Avatar
CLK55 AMG
am I right or does it seem that the 2003-2004 ones are slightly bigger with a larger outer diameter? (03/04: 345mm vs 05/06: 339.8mm)
Old Jan 27, 2012 | 10:54 AM
Johawk79's Avatar
2001 CLK 55 AMG
Uh... yeah. The '03/'04 are 5.2mm larger than the'05/'06
Old Jan 27, 2012 | 03:23 PM
NardoNZ's Avatar
CLK55 AMG
Not so weird I'd say as I was under the impression the rotors were bigger on the 04 models... thanks for the info guys I learn every day!
Old Jan 27, 2012 | 03:48 PM
Johawk79's Avatar
2001 CLK 55 AMG
I added the info for the 2001 - 2002 models too.
Old Oct 1, 2012 | 12:51 PM
Nero Tenebre's Avatar
W209 CLK Renntech Widebody, C140 CL600 V12, AP2 S2000, NSX Twin Turbo, R8 V10
Johawk,
It really seems the 05 CLK55 AMG came with the same brakes as you have pictured last (the CLK63 brakes). I know the OP got his answer of 360mm (14.2") for his 05 CLK55 brakes, which I thought is correct. Where are your diagrams from? Did the OP have a 63 brake upgrade if the stock 55 rotors are 340mm as you posted?
Old Oct 1, 2012 | 09:42 PM
ambit's Avatar
09 CLK550
14.1" I think?
Not sure why that picture broke, I didn't move it and I can't edit that post anymore
Old Oct 1, 2012 | 10:52 PM
Johawk79's Avatar
2001 CLK 55 AMG
Those are Centric part numbers, I think. The diagrams came from my parts look-up at work. I will double check the buyers guides again tomorrow when I go to work. I will also check the O.E. parts book to see if the '05 had the option for the same brakes as the CLK63
Old Oct 2, 2012 | 01:16 AM
Thanks for the response and the pics, I found some other threads talking about it and near as I can tell, there was a 030 performance package or something that upgraded the 05 CLK55 brake rotors to these 14.2" (360mm) units. I found a brochure for 2005 that confirmed OE equipment size was 340mm not 360mm, but oddly enough it did not mention an optional 030 package.
Old Oct 2, 2012 | 10:22 AM
Johawk79's Avatar
2001 CLK 55 AMG
I just rechecked with my parts look-up and the Mitchell reference guide and I didn't see anything about an option in '05 for different brakes. It wouldn't suprise me that MB would give the option and not publish it. Many manufactures do that and the only way to get the right parts is to give the dealer the VIN and get OE part numbers that way.
Old Feb 5, 2013 | 09:32 PM
DaSkorpion's Avatar
o2 CLK 55 AMG || o4 Audi A4 6SP Quattro || o7 Kawasaki Ninja ZX10R
Sorry to thread jack but I'm curious to find out if 2001-2002 #120.35047 rotors on a 2002 CLK55 AMG can be replaced with 2003-2004 #120.35052 CLK55 AMG rotors and will this be a direct bolt on or would I have to upgrade caliper and carriers?
Sorry if this has been asked before - thanks for all the help
Old Feb 5, 2013 | 09:40 PM
Johawk79's Avatar
2001 CLK 55 AMG
You have to upgrade the calipers as well
Old Feb 5, 2013 | 10:03 PM
DaSkorpion's Avatar
Thanks for the info and quick response Johawk79 - very much appreciated.
Old Feb 6, 2013 | 01:32 AM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
And to finish the thought, if we 2002 55 owners upgrade our calipers designed to work with 345mm rotors to the larger 05-06 calipers for the 361mm rotors, 2002 55 owners will also have to swap out their stock 17 inch wheels, if they have them, for 18 inch wheels, is that correct?
Old Feb 7, 2013 | 06:40 AM
cm60k's Avatar
There are a "17 Rims can clear the 6-pot Caliper with 340/345mm Rotors,
but with "18 & above is more clearance with less risky = no Headache.....
ZAYED,,
Old Feb 9, 2013 | 07:54 AM
City Rat's Avatar
Veteran: Army
ZAYED,,
Zayed,
Thanks but I think you misunderstood me. I have 17 inch AMG rims over the stock calipers and and 345 rotors. What I just wanted to confirm was that if a 2001 2002 clk55 wanted to upgrade to the 05 06 361 rotors, he would have to move up to 18 inch rims.
Old Feb 9, 2013 | 11:56 AM
You will absolutely need 18" wheels for the 360mm rotor and caliper. It just barely clears with the oem SL55 5 spoke wheels... This is why you don't see any AMG cars with that kit and I believe the CLK63 has 18" wheels while the 55 comes with 17"
Old Feb 9, 2013 | 01:33 PM
City Rat's Avatar
Veteran: Army
That is as I understood it. Thanks for the confirmation. If my car didn't come to me with the cool AMG rivet wheels then I might consider going to 18 inch wheels.
Old May 19, 2017 | 06:23 AM
vegeftw's Avatar
CLK 270
Hi there. Is there any chance to fit clk500 calipers on my CLK270 plug`n`play? If no, what else should I change? I recently made an upgrade on turbocharger and a remap and i need big brakes too.
Thanks in advance.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
