My Modding Progress
Old Nov 12, 2013 | 01:14 PM
  #301
blackbenzz's Avatar
haters crazy
I've had the motor in and out 3 times in the past two weeks. Unfortunately the forged short block I bought didn't run properly so I'm putting stock motor back in and finding it's limit
Old Nov 12, 2013 | 05:45 PM
  #302
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Man o Man,
10 sec, Betreza marked you sexy.
I don't care what you look like, It is phenomenal.
You are now in testorrossa territory, Having recently toasted a corvette, I am enjoying. this even more.
Cheers, Gator
Posted from Mbworld.org App for Android
Old Nov 12, 2013 | 09:33 PM
  #303
C55er's Avatar
C55 AMG
10.5 c/r
Originally Posted by AMGSC
I am keeping my fingers crossed for both of us. If your engine holds up under this level of boost then so should mine. Thanks for taking the lead on pushing the envelope with this motor. Looks like your CR is the same as mine at 10.5:1 correct? Not the 9.0:1 of the W211 but of the W210 just to confirm? I chose to build my engine at 10.5:1 instead of 9.0:1 so I won't have to run too much boost and still get the power.
The low end would also be crisper with the higher c/r. Would you by chance have the PN of the pistons? Thanks.
Old Nov 13, 2013 | 08:06 PM
  #304
2PRECISE's Avatar
clk55 amg
unfortunately CR in not what is advertised
Old Nov 15, 2013 | 10:49 PM
  #305
C55er's Avatar
C55 AMG
c/r
Did you find the 210 c/r higher or lower than advertised? It appears the PNs of the pistons of the 113.980 (210) are not the same as the 113.990 (211). However the heads are not the same as well. It is likely a case of piston/chamber combination, not just piston. The 113.988 which I have on the C55 (11:1 c/r advertised) shares the same head PNs as the 113.980 but has pistons unique to the 113.987~113.989.
Old Nov 23, 2013 | 07:51 PM
  #306
blackbenzz's Avatar
haters crazy
Replaced a bent valve and put the stock bottom end motor back in with ported heads. Making more power than it ever has. Hopefully have it tuned Monday and 1/4 mile times soon thereafter. Running dual Bosch 044 fuel pumps now. Whoever said these motors are weak doesn't know what they are talking about. I expect 650+whp shortly (making 620+ running very lean right now). We will see if it holds
C/r is lower than advertised.
Old Mar 27, 2014 | 09:38 PM
  #307
blackbenzz's Avatar
haters crazy
Just an update. Ran 10.31 @ 134 mph today. More to come with some more tuning Goal is 9s @ 135+
Old Mar 27, 2014 | 10:11 PM
  #308
betrezra's Avatar
C63 507 AMG DA Car #19
Nice. Pushing envelope!
Old Mar 27, 2014 | 10:44 PM
  #309
dre5373's Avatar
2006 C55, 1995 C36
WOW!!! Congrats Ahmad!
9's on a stock short block would be unbelievable!
Old Mar 27, 2014 | 10:54 PM
  #310
dsp_tdi's Avatar
2005 C55
Crazy car!
Old Mar 28, 2014 | 10:16 AM
  #311
blackbenzz's Avatar
haters crazy
Thanks! I definitely think it is doable. This is a junkyard block with over 100k miles on it too lol. If I take some weight out it would make it alot easier but lets see if I can do it full weight. Wish I had some good headers on the car.
Originally Posted by dsp_tdi
Crazy car!
Old Mar 29, 2014 | 12:33 AM
  #312
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Nice feat! You are one persistent enthusiast! You keep this board interesting.
I will just live vicariously through your car as I don't have the knowledge or skill to chase your accomplishments. It takes a lot more than just hardware and software to get to where you are at. It takes blood, sweat and tears.
Old Mar 29, 2014 | 06:20 AM
  #313
FFXF1's Avatar
2003 Chevy Tahoe
Ahmad - Congrats on the times, and great job hanging in there despite all the unfortunate set backs. Look forward to catching up with you at the track one of these days. Who's doing your tuning now?? You're not back at the previous european tuner in the DC area are you??!
Old Apr 1, 2014 | 01:09 AM
  #314
GatorMB's Avatar
Right on,
I had the skill and determination when crafting special cars at one time in my life and happy to see others with the same merit.
Slumps are temporary but BB never quit. Your the champ here BB
Gator
Old Apr 18, 2014 | 04:21 PM
  #315
blackbenzz's Avatar
haters crazy
Decided to go to MIR today and play with the fuel pressure since I couldn't get a tune done to get the afr's where I want them. Full weight, drove 2 hour to and from the track. Just added ice and changed intake setup when I got there. Tires still rubbing real bad on the launch and I'm pretty confident I can cut another 0.1 seconds off the 60' which should translate to 0.2 on the big end. Here is the break down of the run and I believe some guys got it on video (Mustang rental) and should have it loaded by Sunday.
60' 1.555
330' 4.336
1/8 6.616
MPH 107.76
1000' 8.577
1/4 10.235
MPH 136.17
Huge improvements were seen on same day after I tweaked fuel pressure. My first run was 10.5@133 before I messed with fuel pressure. Then I ran 10.2@136 with Ahmad tuning Imagine what it would do with an optimized tune and no tire rubbing!
Car is over full weight boost only. STOCK bottom end with over 100k mile junkyard motor. I will be back at the track Monday to make some changes and hopefully be in the 9s
Thanks to Weistec for the SC and Eurocharged for the base file that I tweaked fuel pressure to work better. And MIR for the track prep
Old Apr 18, 2014 | 10:48 PM
  #316
betrezra's Avatar
Holy mph!!!
9's. Hello yeah
Old May 2, 2014 | 03:41 PM
  #317
blackbenzz's Avatar
haters crazy
Car ran 10.09 @ 138 mph with race seat and no back seats. Couldn't get the car to hook this time. Then the engine let go and made the best window I've ever seen. You would think I was a software engineer! Lol. It happened at 100mph and oiled down the tires and took me for a ride. Luckily I was able to keep it out the wall. 06 E55 engine on the way and I will tear it down and put forged pistons, rod bolts, and arp heat studs in and try again
Old May 2, 2014 | 07:50 PM
  #318
FFXF1's Avatar
2003 Chevy Tahoe
Ahmad - you are amazingly persistent! You go through engines like women swap shoes - UFB!! Quick question - have you thought of cryo-hardening your internals?? Did some reading on it, sounds interesting...
Old May 2, 2014 | 09:06 PM
  #319
betrezra's Avatar
Pretty impressive for a used mystery n/a 55 motor....!
we'll call you the PUNISHER.
so close to 9's
Old May 2, 2014 | 09:08 PM
  #320
blackbenzz's Avatar
haters crazy
Haha thanks No, I was seeing how far I can push stock internals. Next motor will be forged inside
so close to 9's
Haha Thanks. I want a clk bs so I will probably seel the car if I fidn the right potential buyer. The car will have 06 E55 motor with forged pistons, rod bolts, and arp head studs.
Old Jul 12, 2014 | 07:23 AM
  #321
Moedy's Avatar
'05 CLK55, '04 CLK320
Wow fantastic time!! I haven't been on the boards lately and looks like you've made lots of progress. Congratulations! Just curious, since you're going to be swapping in an E55 motor into it, why don't you use some nitrous and go all out to see what's the best you can do with the old motor or are you spraying already?
Old Jul 13, 2014 | 11:01 PM
  #322
blackbenzz's Avatar
haters crazy
Thanks Well the motor blew up so that's why I got E55 engine. I'm putting in forged pistons and rods in the E55 engine before putting it in my car. I wasn't using nitrous on my car, the motor could't even hold the boost lol. But I will be back stronger than ever
Old Jul 25, 2014 | 02:37 AM
  #323
Moedy's Avatar
haha damn I wasn't thinking you meant you blew the engine when you said the engine let go. Looking forward to seeing the E55 motor in it. If that thing runs reliably I would keep it forever
Old Aug 5, 2014 | 01:14 PM
  #324
blackbenzz's Avatar
haters crazy
This thread is lacking pics lately so here are a few to spice things up lol.
Current headers (only 1.6" primaries and each pair merges into a single 1.6" pipe; downpipes only 2.35") LOTS to be gained here
Flanges made. Counter sunk to locate pipe easier
What the block will look like with Darton sleeves
Custom high compression pistons arrived yesterday. First pic was before they were sent out showing before/after coating\
And finally in my hand
Old Aug 5, 2014 | 02:18 PM
  #325
cm60k's Avatar
Daaaaamn bro.,
are these JEWELERS...
ZAYED,,
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
