My Modding Progress
I will keep you posted. I didn't end up dropping my car off at the header place. The guy turned out to be a worthless unprofessional racist. Won't get a dime of my money. I will take it somewhere else next week
BB, I had the same issues your having. Looping the fuel rail resolved the issue for me.
At high rpms cylinder 8 goes lean and triggers the misfire due to uneven fuel pressure at the injectors. Looping the fuel rail balances the fuel to all cylinders at all loads.
For me the problem showed up when i increased boost and put more demand on my fueling system.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
CLK55 '05 CLK320 '02
So true. Options are a good thing
I took the rail off today to get it looped and noticed the y from the valve cover breathers was no longer in the tb. I also swapped injectors from cylinder 8 to 5. Thought that fixed it but nope same misfire and still in cylinder 8. So I added a bunch of resistance to the MAF wire and there was no more misfire!!! I need to dial in the MAF voltage properly and then get the car retuned and out to the track!![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
sounds like ur figuring it out one step at a time. good luck with that keep me posted with ur progress
C63 507 AMG DA Car #19
Now we're getting somewhere! Prob pegging the meter. Curious to see what your voltage is up in the load.
I understand from cory they have to sometimes go thru 5+ meters until they find one that will work on these klee cars..... the sensativity is much more critical when you force 2* the air through the stock meter element. It's resolution becomes more important.
Good luck.
Good luck.
#33
Good luck.
Good luck.
Thats crazy, I wonder why MB went with such a bad MAF and hasn't come up with a better replacement.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#34
frankenstein 2001 CLK 430
The resistor came with the Kleemann SC and has been on the car since the blowr was put on many years ago. If my memory serves me correctly it is a yellow wire with white stripe. It is pegging it because when I dialed in more resistance it wasn't pegging anymore. I'm reading 11PSI with ported heads on my boost gauge
when i went from .4 bar to .8 bar the car was leaning up top (15~16), so i never got shift 4th in it, so i added another resistor (510ohm) totaling now to 1020 ohm, and the car was running much better 12~13 AFR, so i increased my fuel pressure gauge from 5 bar to 5.8, and AFR became 11.5~11.9,
#35
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Whoa, that's brutal man, sorry to hear that. I just got back from being without Internet for a week so I have lots of catching up to do on your and Jeff's threads.
#37
Adjusting the MAF properly is proving to be more of a PITA than I expected. I will hook up a voltmeter and try to get it right this weekend but it seems like I may have maxed out the resistance. At one point I had it running decent at wot but it was idling at mid 11s AFR!
Ever since I've been adding resistance and now it idles ok but studders in third gear at wot
Hopefully I can figure it out this weekend. Otherwise I may order a split second unit or something.
I'm going to opening day at one of the local tracks this sunday to try and get MAF voltage right. Also picking up some parts I bought (SRT 3.06 diff with wavetrac and DSS 1400hp axles). Going to try to see if I can fit them in my car and do some wheelies![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Funny you should mention him. I saw the headers in person a while ago and he said he would never want to do it again ll. Said you have to pull the motor to install them. Anyways, he made my exhaust from headers back. Unfortunately I lost his cell number when I switched phones
You should hear the voicemail this guy left me, it's rediculous!
Thanks for the contact info
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
for sure about the headers dropping boost but increasing flow which is much better, i am very interested in them too, i saw the headers on blackonblackCLK and sent him a PM about them, but no reply... i wish he posted a picture of the drivers side where the main problem is, i think i have a shop here in lebanon can do them for me, but using normal iron 2mm thick, not Stainless Steel.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
#38
Thanks for the contact info![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#39
'05 CLK55, '04 CLK320
#40
Quick update. I cranked on the MAF resistor about 20 times to try and get maximum resistance on it. I then ran a wire into the cabin so I can monitor voltage from inside the cabin. I did 1 third gear pull and MAF maxed out at around 4.88V but I didn't quite hit redline and it didn't misfire. It started raining so that's as far as I got. I really like being able to monitor the Voltage from inside the car. I think I need a bigger custom MAF housing or a bigger resistor especially with the future mods I have planned. More updates to come Sunday when I go to the track on street tires and get more data on MAF voltage and pick up my diff and axles. Hopefully be ready in time for March 23rd, doubtful headers will get done before then but I just hope its runing well with axles/diff
I should be able to hit this years goals if everything goes right March 23rd
But I am far from done
I'm glad you like it becaue I wasn't sure if it was a big enough difference in gearing to really notice. I hope it fits! It's a bigger diff so I'm hoping it fits with the axles with slight modification. We shall see. Yes I can do that or get Jerry to reprogram the TCU, maybe switch in even shorter gears later down the road. Thanks forthe input Ahmed ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
It wasn't just rude, it was full of profanities and racist slurs. All because I said I was dealing with a misfire issue and might need to hold off on the headers. Keep in mind we had nothing planned besides him looking at the car to see if he can do it and how much. Once he said it's cash only thing I got skeptical, then once he reacted like that I was glad I didn't take it
#41
#42
BB - Could you have a custom shop use you klee headers as a starting point (flanges at block and partial header pipes), then go from there on down? Should save a few bones and make this a smaller job. Just a thought.
#43
Well only things that I would reuse are the flanges and at the point its just better to sell them and get new flange made. The primary pipe diameter is too small for my liking and having two cylinders merge into one pipe that's the size of one primary is really bad IMO
#45
Well I made two passes spinning half way down the track and no misfire. Picked up my axles and diff and I thought everything was great! I was wrong, misfired on way home and outer CV is too long and hubs won't work. I ordered a new maf sensor to try. Sometimes the voltage at idle is good and sometimes its high. I think maybe the sensor is bad. This thing is trying my patience!
#46
BB - how about some strategic wgt reduction?
100lbs is +/- a tenth.......
Oh how about a 40 shot for cooling effects?
Do you find a cool down makes a diff between passes? Of doesn't matter?
If you're spinning still how about some real slicks?
Thinking you have a high 9 in that beast with some tuning.
#47
I'd like to get some clean no nitrous runs before playing with nitrous although blower cats love the stuff.
Cool down definitely makes a difference. What I did today was show up, go to tech, go straight to staging lanes and make a pass. The goal was to see if misfire was gone. It didn't misfire at track but I tried on the street and it was back! Grrr. I ordered a new may sensor to try. I was running on street tires today. Was pointless loll
I hope you're right. But the kinks need to be worked out. One step at a time I guess
#49
