Clacking Sound On Start Up??
Old May 17, 2012 | 08:47 AM
400HP55's Avatar
2001 CLK55 AMG
When I got my new engine put it, the mechanics said it had a clacking sound when they started it up for the first time. We figured it's because the engine hadn't been started in over 2 years. So we wrote it of because after they let it idle for about 5 minutes it went away.
I wasn't there when they started it for the first time and heard the clacking sound.
So I haven't stared my car in about a month because I've been working on my suspension. I started it tonight and heard the clacking sound. Didn't sound good at all! But it went away after 5 minutes of letting it idle.
It sounded like it was coming from the bottom end.
Any ideas???
Old May 17, 2012 | 01:04 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
"Clacking" may be a different sound to you than me. "Clacking" is a higher pitch to me and that is usualy valve train. "Thumping" is a lower pitch to me and usualy a problem in the lower end. A rod knock doesnt just go away after a few minutes of running. Does it still make noise if only let sit for a few days? May just be a "lifter" bleeding down.
Old May 17, 2012 | 03:58 PM
400HP55's Avatar
2001 CLK55 AMG
Its not a thudding sound. It's Weird haha. If I let it sit for a week and then fire it up the sound isn't there. Sounds Only there if its sitting for more than 2 weeks. It just worried me!!!
Old May 17, 2012 | 08:51 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Our ML500 and my clk55 sometimes does this after it sits for a while.....then goes away after warm up.... then not present for days/weeks/months...... I was thinking lifter pump up..... but purely guessing. Reminds me of aftermarket roller rockers that need a shim from my domestic product days
Old May 18, 2012 | 02:29 PM
bobbyjo9's Avatar
Like many others, mine too will make a little valve tick on start up if I let it sit for a few weeks. With the road you've just been down I'd be nervous too! Doesnt sound like you have something to worry bout this time though.
Old May 19, 2012 | 10:55 PM
boxeswithknobs's Avatar
BMW 528i
Sounds like it's probably valve train/lifter noise.
After the car sits long enough, residual oil coating drains and thins out at the top of the engine. 1st start gets to ticking/light clackety until oil pump creates enough pressure at the top of the engine to fully restore oil coating.
Not unusual, when I leave a car sitting for a while (+ months), I normally pull the fuel relay and give it a couple start turns to get some pressure built up before plugging the relay back in for a "real" start.
Old May 19, 2012 | 11:09 PM
400HP55's Avatar
2001 CLK55 AMG
I don't know why I didn't think of that
Same thing for priming a new turbo.
Old May 20, 2012 | 11:07 PM
400HP55's Avatar
2001 CLK55 AMG
I know its off this threads topic; however, I'll ask anyhow. Do you guys think the Flex Disc should be added to 100k mile tune up?
