HOLLOW OUT A CAT?
He kind of tempted me to do the same but I am very hesitant. I do not want to throw any codes. We do not have emissions in Michigan so it would never really be a problem. Would do something like this cause any damage or throw any codes? My friend is such an *******
lol. He keeps pushing me to do it but I keep telling him no.
What you should do if you want to go cat less is remove your functional cat and replace with a straight through pipe, it shouldn't cost much too. You then have the option to revert.
By the way it sounds so bad ***!
What I’m also missing is the point. Aside from ruining a perfectly good cat, it would make a low pressure zone, thereby slowing down gasses. Assuming you don’t know what I mean by this, in a nutshell the exhaust will flow worse than if a straight pipe were used. Also, there is a chance of not getting all the substrate material out of the cat. And what isn’t removed will eventually break free. Substrate chunks may work their way out of the exhaust. On the other hand, they may get stuck in one of the perforated tubes in a muffler chamber (also bad for flow).
I would have a "race pipe" fabbed and keep the stock h-pipe for when you get old like me and don't want the noise anymore.... or if you sell it.
GL>
He did a pretty good job making sure that no chunks were left over. That included lifting the whole system straight up into the air a few times, vacuuming the little chunks and then finally blowing air into the system to make sure that nothing was left over.
Is he in for a rude awakening?
