Brake fade
I figure I'll flush with some good fluid, but I don't know how much that will help. Will it?
What else would aid things? Pad selection? I don't want to grind up those expensive rotors too bad.
Also, does hitting the ESP button allow real tail out shenanigans, or do I have to put it in "dyno mode" to let that happen? I want to keep ABS up, but I kinda stood on it and didn't get much wheelspin or any real drifts. Granted it was the first time I'd driven it in anger...I probably need a little practice.
As you've guessed, fade usually comes from one of two things, cooking the fluid or cooking the pads.
First, what type and how old is the fluid? If "I don’t know" is the answer to either question, that usually means a flush is due (and depending on your driving skill, that could be the entire problem). Many flush after track days as a normal policy. Once the fluid has boiled once, it's toast, so you're due now either way. Which fluid? The short recommendation is ATE Super Blue or Typ200. A longer answer is here.
The pads . . . . . .honestly, most street pads can be cooked in a few laps. The attached photo is one of my front OE pads. They were overheated to the point where the glue that holds the friction material to the backing plate melted. It's my opinion that if the car is a street car, a second set of "track pads" are not a bad choice. On the street, those track pads will screech, dust, and have less bite when cold. However, they won't overheat at track events. Many people swap wheels & tires before/after track events. At that point, pads will only take a few minutes, and since the fluid has to be changed anyway . . . .
Which pads should you buy? Depends. Will you mind if the pads devour your rotors? Other than to/from track events, will they be used on the street? If used on the street, a lot will depend how much annoyance you are willing to put up with.
