DIY: Kleemann SC Water Pump Leak Fix
This past weekend I was able to confirm that the Water Pump was the root cause of the leak and following Cory's advise, I was able to repair it successfully. There was one hitch though, the screws are being held in a plastic housing and I found that one of the screws has stripped the plastic housing, thus there was no tension on that side. For that screw, I had to buy a new screw and nut (pictured below). In any event, I have documented the fix below for my Kleemann SC brothers! First the disclaimer:
IMPORTANT DISCLAIMER: This DYI is to be viewed as a literary work, which is to be used for entertainment purposes only. These are not assorted sets of instructions to assist anyone in modifying, repairing or maintaining a car, motorcycle, truck or any related parts. Working on modern cars and/or car parts is acutely technical, and I highly recommend that you hire a professional to service your car. This DIY contains information about what a professional MIGHT do when working on a car, and equally as important, why they may do it. The author of this DIY assumes no responsibility for inconveniences or damages resulting from use of the information supplied. The consumer or reader is individually responsible for his or her use of the information supplied and uses this information at their own risk. The author of this DIY has no liability for errors, omissions, or any defects whatsoever in the information or instructions, or for any damage or injury resulting from the utilization of said information or instructions.
1. The top view of the water pump housing, the screws circled must be tightened. In the end I found that all 5 screws were loose.
2. The side view of the water pump housing, again tighten all the screws. The screw circled in red was where the coolant was leaking from and was the screw that was stripped.
3. Close up of the problem screw.
4. Picture of the new screw
5. The nut that holds the new screw.
In my opinion, I may have damaged the old C090 by possibly running it dry when I replaced the Heat Exchanger (when I first replenished the coolant lines). I will never know what the root cause of the failure was, but the leaking started after I replaced the Heat Exchanger. The C090 data sheet says NO DRY RUNNING and even has a big red sticker that says this. I know for a fact I didn't run the CM90 dry for 30 minutes so I should be good now.
Now the pics:
C090 (Left) vs CM90 (Right)
CM90 (Top) vs C090 (Bottom)
My aftermarket HE is making a HUGE diff in 100 deg F no loss of power like before.
Keeping this thread in my notes for "when" my pump takes a dump.
Kleemann brother #13002
I've been following your threads too, Jeff! I'm a BIG fan of your paint scheme/mods!
Right now I'm currently looking into CF interior, Coil-Over Suspension, and Eaton SC Porting.
When I came home I investigated and found the problem was the coupler between the pump and the coolant hose. I decided to upgrade both couplers and the hose clamps and I would like to report that I have no problems thus far. My hypothesis is that the CM90 produces more pressure and thus the hardware needs to be more heavy duty.
The HPS coupler (bought from Amazon) I went with is one size smaller (35mm) than the original coupler, so you have to massage the hose together; but that sucker is not coming off! I have attached a pic to this post.
I bought two of the Meziere fitting 1" barb to -12an o-ring (Kleemann System uses 1" coolant hoses), the supplied O-Ring is good enough to stop leaks.
First impression is that the Meziere is a smaller pump than the CM90 and it must be mounted vertically, so you have to make some new brackets. I didn't find any problems finding a place to mount it.
The car is still running great, she still pulls very hard through the gears! I'm very happy with my setup!
