Check engine light 2005 CLK55
I got check engine light last night while driving slow. I don't have the scan reader but I did some search so the possibility are: MAF sensor, gas cap and Oxygen sensor. Do you guys think better just replace it or clean it ? I will fill up the gas with a bottle of Techron to clean the system. I really hope is not the exhaust or need to replace MAF sensor. However, I felt the car is not as fast as the 04 CLK55 I had before. Thanks for any advise.
Good luck
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
Potential causes of a P0432 code include:
- Bad or non-functional catalyst
- Engine operating out of optimal air:fuel ratio
A code P0410 may mean that one or more of the following has happened:
- Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump
- Blown AIR pump fuse due to freezing up
Thanks !
