slow crank start-up. 2006 CLK55
just noticed that sometimes it takes 1-2 seconds before my car engine turns over and starts. can't quite isolate whether it's while engine is cold or warm, but sometimes even after i release the key on the ignition turn, there appears to be a 1/2 second delay.
from my prior MBs, i'm thinking it could be:
battery
alternator
MAF
starter
any thots would be welcome.
PL
The Battery, Alternator, Starter question can become a vicious circle.
I would start by having the battery load checked, the terminals must be clean and the cells full of electrolyte. (acid,water). If a lead cell has been exposed to oxygen from low fluid the battery is going to fail.( electrolysis degrades the plates and the waste collects into the sediment chamber at the bottom). short circuited cells.
Any value below 10.4v while cranking is indication of a bad battery.
A failing starter will drain a battery fast. When suspecting the starter put a booster on the main battery and test the voltage drop. Current drop testing is better but these high amp DC testers are more $ than a new starter. Consider the age of the starter and battery condition before committing. If the starter is getting hot by touch on a cold engine while attempting to crank it is likely toast.
The alternator/regulator on these cars work great but when the brushes start to wear, intermittent charging problems occur. The regulator w brush assembly is an easy fix and inexpensive but not always successful when the commutator rings are burnt and scored. If the alternator is not putting at least 13.8v @ 1000 rpm with a known good battery then fix or replace. An overcharging alternator w 14.5v @ 1000 rpm is going to boil all the acid out of your battery starting the viscos circle all over again.
Cheers, Gator
