A/C Problem With Data
10 Minute drive in the morning about 68 degrees outside.
1.)74
2.)84
3.)79
4.)78
5.)78
6.)192
7.)10
8.)85
15 Minute Drive 82 Degrees Outside
1.)85
2.)107
3.)92
4.)91
5.)91
6.)195
7.)15
8.)10
Low pressure readings on a 80^ day in the sun should be around 60
High pressure readings around 275 - 325 with the condenser fans on.
The low pressure switch usually kicks the compressor off around 20.
If you are reading 30 which is low the pressure will drop low enough kick the compressor off under mild acceleration.
Really need to see the high pressure reading from a refrigerant gauge set. If we observe the high pressure is too high and the low is too low then the system is plugged.
Gator
Code 1 = Inside Temp
Code 2 = Outside Temp
Code 3 = Left Core Temp
Code 4 = Right Core Temp
Code 6 = Coolant Temp
Code 7 = Refrigerant Pressure (This is the important one)
Code 8 = Refrigerant Temp
Debris from the compressor collects in the condenser creating extra high pressure. Heat saturated freon never gets to liquid form which is required for the expansion valve to atomize the freon. Flushing is required
Other forms of blockage in the expansion valve include moisture on the needle valve assembly that corrodes the needle action, the valve never opens and has limited flow.
I bet it is low on freon, to check the drier on a charged system just feel it by hand, it should be hot on a healthy system.
Cheers
Oh, and does anyone know the correct Low-Side recharge Pressure for a CLK 55 in about 80 degrees ambient weather?
If the pilot valve acts up it can cause a lot of different symptoms. Most from the past stop pumping period and adding freon never recovers the system.
Sensor readings are for general use by us and required by the control system to moderate air flow and temperature, cooling and heating. Nothing replaces hanging some gauges on the AC system to determine health.
An empty system should be evacuated at least 30 minutes prior to charging. The vacuum pump removes moisture from the system and keeps it healthy in many ways.
All the Best
Yes, the Wankel is fun but it needs apex seals badly, I can smoke the block out with just oil burn if I want to.. It's a project car, I'm actually restoring it back to original, plus some extras. I want to do an FC injected 13b since 12a's are becoming rare to get parts for, blocks are impossible to find, plus the fuel injection will be NICE, with the extra power especially. I also need to find a gsl rear end with Disc brakes. I'm adding all of the electronic extras it didn't come with, I have the equalizer and fader / balance joystick... Trying to pinout them correctly to work with my aftermarket eclipse deck. Been some work.
