W209 CLK55 M113k build thread
Old Jan 7, 2016 | 01:57 AM
kb24forlife24's Avatar
None for now
Man that was fast. Props to you! Can't wait for the pictures and videos...
Old Jan 7, 2016 | 11:21 AM
Chadzu's Avatar
2001 Clk55 AMG
Looks good. I hope you can figure out the programming and get all the systems working properly.
Old Jan 7, 2016 | 02:31 PM
Tex5's Avatar
CLK 63 AMG Black Series, A45 AMG
Great work
Old Jan 9, 2016 | 11:40 AM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
That does look like a lot of fun and I would enjoy seeing it @ speedworld.
C32 has a nice cave to work out of and it helps a lot that we are in the 70's which is good wrenching weather.
Keep it up bro, :-)
Old Jan 10, 2016 | 02:48 PM
DutchC54's Avatar
1998 W202 C43 ///AMG 5.4
very very nice swap!
im really impressed.
can u please share some info on the wires/connectors, what u soldered where how etc etc.
ive thought about doing something similair in an W202 in the near future.
allready swapped an 4.3 to 5.5(no "K") from E55 but i really would like a charger added to it.
Old Jan 14, 2016 | 11:18 AM
c32kompressor's Avatar
CLK55 AMG
Okay, so everything is done with exception of the ecu. I tried to apply the scn coding with no avail. Can anyone that has done this swap give me some input on how they got the modules communicating? Did anyone use star developer? I'm almost out of ideas and could really use some input on what might be the key to get this thing to start. Thanks!
Old Jan 14, 2016 | 02:14 PM
  #32
sick430's Avatar
CLK Cabrio
talk to moneyone on the site. hes not really here anymore but did this to a 202.
Old Jan 15, 2016 | 10:37 AM
  #33
GatorMB's Avatar
There are strong versions of WINOLS that will custom tune the ECU. It is recommended to find some one fluent with its use though.
I am sure that there are higher variants that can complete the ECU though. Try PM one of the onsite tuning vendors along with Kleeman. This might be the easiest and fastest way to go.
Cheers
Old Jan 15, 2016 | 10:39 AM
  #34
CLK55 AMG
Awesome, thanks! A lot of great minds on here! She'll be going in no time!
Old Jan 15, 2016 | 06:29 PM
  #35
CLK55 AMG
She fired up today!! I'm finishing everything up tomorrow, and I'll upload the rest of the pics and post a video. It sounds so nasty!
Old Jan 15, 2016 | 06:32 PM
  #36
Blitz2639's Avatar
2008 E350, 2010 GL550
What was the answer with ME and the coding?
Old Jan 15, 2016 | 06:53 PM
  #37
CLK55 AMG
Well, I was trying to apply scn coding to the module, when the module wasn't exactly a virgin. Since it came out a vehicle that runs the m113k, it already had the scn coding on it. The only thing cleared was das and the vin. I burned the new vin in the module and, bam! All was well! I was getting so frustrated with it, my mind became a little clouded. I took a days break, came back in with a clear mind and figured it out.
Old Jan 15, 2016 | 07:02 PM
  #38
CLK55 AMG
A BIG THANKS to everyone who answered my questions! This forum is filled with really knowledgeable and awesome people!
Old Jan 15, 2016 | 10:43 PM
  #39
tw2's Avatar
tw2
Congratulations. I bet it is fantastic. I know this is a huge ask but I am sure there are a few people out there who would love to see a writeup on what is involved.
Old Jan 16, 2016 | 02:41 AM
  #40
None for now
Wow that was quick man. You have a sleeper! Can't wait for the pics/videos.
Old Jan 16, 2016 | 08:56 AM
  #41
CLK55 AMG
Already ahead of ya!
Old Jan 19, 2016 | 12:29 PM
  #42
Emil_123's Avatar
C32
Whoa, congrats man!
Old Jan 19, 2016 | 05:35 PM
  #43
Samito01's Avatar
2004 clk55
Wow awesome I have a clk55 with 41k on the clock....but am interested in doing this....just trying to figure out if I can just do the supercharger only
Old Jan 19, 2016 | 06:38 PM
  #44
CLK55 AMG
No sir. The engines are different.
Old Jan 19, 2016 | 07:27 PM
  #45
tw2's Avatar
tw2
I believe you can but as mentioned above the engines have different compression ratios, you need all the pulleys and mounts since 55k has two belts. You will need new injectors, TB and intercooler heat exchanger pump, wideband and maybe 55k water pump or outlet at least. Oh and a voltage clamp if retaining the maf. New fuel pump too. Lots of tuning. It has been done.
C32k - did you have any problems with wot shifts on your old setup? Not hitting the torque limit?
For the new setup it looks like you used a 55k transmission?
Old Jan 19, 2016 | 09:40 PM
  #46
CLK55 AMG
The car was originally a 55, so generally speaking they are the same 722.6 amg speedshift 5 speed
Old Jan 19, 2016 | 11:44 PM
  #47
sick430's Avatar
CLK Cabrio
Yes, you can do a supercharger install on your car. It's been done a number of times. If you remove the clutch pulley and install a regular one on the supercharger it will save you a lot of headache. But you will get horrible MPG!! Just FYI. There are a number of tuners that can do this for you. I like it as it gives the car that OE look.
Old Jan 20, 2016 | 12:53 AM
  #48
tw2's Avatar
tw2
Thanks, the reason I ask is simply whether you used your original TCU with a new transmission or not and whether coding was required.
Sorry to ask again, did you experience any problems with the old setup in terms of shifting smoothly, hitting torque limit etc? Thanks again for sharing your experiences.
In terms of retrofitting onto a NA M113, the only problem I can think of is the bypass valve in the supercharger when you use the stock 55 NA ECU with the supercharger. I don't know how you can control this- I presume it is electronic as well as vacuum controlled? A clutched pulley could potentially be controlled with a simple throttle % activation but this couldn't be done through the stock ecu. Fixed pulley is easier but the bypass is imperative in that case.
Old Jan 20, 2016 | 09:40 AM
  #49
CLK55 AMG
The internals are different. Aswell as block construction. You are way better off with a kleemann kit.
Old Jan 20, 2016 | 05:53 PM
  #50
Samito01's Avatar
2004 clk55
Thanks....when the time comes m113k it is
