W209 CLK55 M113k build thread
Old Oct 30, 2016 | 09:46 PM
  #76
c32kompressor's Avatar
CLK55 AMG
Originally Posted by Khan 55
C32Komp. Tell me, who helped you to code the vin to the engine ECU? Was is DTK themselves or someone else?
I did the coding. I have a mercedes independent shop down here in swfl.
Old Oct 30, 2016 | 09:48 PM
  #77
CLK55 AMG
Originally Posted by MouTine
It would be nice if you C32Komp could do litle write up. I'm specialy interested wireloom modifications and codeing. What modules you used from CLK and what came from E55.
I used an ecu from a w220 s55. I just had to swap a few pig tails
Old Oct 31, 2016 | 01:48 AM
  #78
MouTine's Avatar
'14 E500 Coupe
Ok. So only two things that came out of S55 was the engine and the ECU? Engine wire loom is the orignal CLK and you just
added wires for SC clutch? ECU ja instrument cluster needed to code together? Ok... I got the picture... Thanks.
Old Oct 31, 2016 | 02:13 AM
  #79
CLK55 AMG
The engine is from a e55. It came with the engine harness. Just the engine computer needs to be codes.
Old Nov 1, 2016 | 02:52 AM
  #80
Khan 55's Avatar
2004 CLK55 AMG W209
Thanks for your response on the ecu required and the coding. Only a Star can achieve this correct?
Old Nov 1, 2016 | 09:43 AM
  #81
CLK55 AMG
That is correct
Old Jan 22, 2017 | 10:45 AM
  #82
buffyclk500's Avatar
clk500
Does this set up cost less then doing kleemen set up
Old Jan 22, 2017 | 11:40 AM
  #83
CLK55 AMG
I work on these cars for a living. There fore my cost was cut in half. It would probably be around the same
Old Jan 22, 2017 | 11:56 AM
  #84
clk500
goid point
Old Jul 13, 2020 | 07:30 PM
  #85
Khan.Exclusive's Avatar
W209 M113K
Currently doing the same swap, i have an ECU of a w215 cl55. Will that work? And how did u code it?
Greetings from Holland
Old May 13, 2021 | 03:13 PM
  #86
toppyfliegt's Avatar
SL500 (R129), C32 AMG (S203)
from M113ML Work all. Have to virginized and coding.
Best regards from Germany
Old May 14, 2021 | 04:49 AM
  #87
Okay guys, a little update. My fuel pressure was a little low. The stock system runs 65 psi. The m113k needs atleast 80. After trying different things, this is what worked for me. I used a 6.0 bar internal fpr filter from a 2010 vw gti. It was a direct swap in and it works perfectly.
so you us walbro Pump and fpr Filter TFSI together now and works good?
Old Jun 8, 2021 | 08:31 AM
  #88
Fidel_CashFlow's Avatar
CLK55
Is that all you need to do when it comes to regarding fuel? Or did you have to get a different fuel pump? Also your PMs aren't open lol
Old Feb 22, 2022 | 03:30 AM
  #89
antoineW20955K's Avatar
w209 swap M113K
hello, I'm swapping a clk55amg into a 55amg kompressor M113K I'm bored with two sam connectors before I saw that you had the same problem I took the liberty of writing to you because today I'm not find no wiring getting me out of this
Old May 2, 2023 | 07:01 PM
  #90
PitCrew's Avatar
'05 C55, '95 320E
Need guidance
Just send me a pm!
Anyone have this write up?
Old May 4, 2023 | 10:14 AM
  #91
Doklsa497's Avatar
AMG
Fantastic build indeed!
