W208 supercharger, what's everyones setup?
So what's everyone got on their w208? What boost do you run? How much power do you make? Just want to see what's out there and what I could get to.
Obviously it is a cabriolet so I'm not going for fastest 1/4 mile or anything, just a fun weekend car that can surprise people
M113K has the main benefit of being OEMish in reliability and not requiring tuning which is always a great place for stuff to go wrong. Also much better than roots in most ways.
was a former members car I believe. for everything not a bad deal. and you could probably get a lower price without the ecu/key/cluster. go to kleemann and have them tune it.
There is a circuit that turns on or off the diaphragm for our WOT burst HP. I will build a controller that uses this principle.
Best, Gator
I agree the kleeman might yield the best results.
The E55 SC assembly is incredible heavy plus boost is marginal. I have a well seasoned engine with all the wrong parts for SC but we must experiment with burnt rubber.
PS: I was close to Maryland today
Best, Gator
I am outside of Philly...So I'm listening.
Issue is right now I don't have the money(unless someone is practically giving something away), just trying to figure out how much I will have to save up. Which options are best, etc.
The NA55 runs higher compression and longer lobe centerline cams which reduces valve overlap under 2 psi boost from the tuned intake runners.
It will take much reverse engineering on the E55 Blower. The E55 uses blower bypass control circuit which I have to study a bit before bolting it on and powering up the blower clutch.
This will be good for one fast run only. Likely send a piston through the pan fast.
To run the E55 SC full time would require an aftermarket boost control plus a chaser truck to refill the fuel like the movie "need for speed" Awesome movie.
I will likely work on a controller that is linear and also adjustable for smooth operation of the SC bypass actuator. (there are two one is for intake air). 6-10 psi at the most.
Theory is to keep the OEM ECU and MAF. custom intake air pipe required.
Best, Gator
You will need a MAF voltage clamp. I believe it will work ok as long as the fuel rail is adjusted and the tuning is done carefully and conservatively.
Unfortunately the whole engine/ecu combo is still the best way to go for reliability and performance.
I agree the MAF input will utilize best control of the bypass valve also boost limit.
Have much research to do and preparation of my seasoned engine Timing chain replacement, and oil pan removal for bottom end refresh.
A friend of mine at work does mustangs and informed me about SC controls on some of them are similar. I would suspect that there is a retrofitted mustang or two out there with aftermarket controls.
One other input the we usually never discuss is Exhaust gas temp. This is a must for over boost control and lean conditions.
There is quite a bit of information on this in the turbo diesel forums and you tube superturbo diesel Finland. These folks have re-written the book on Mercedes Turbo.
Will be reflecting on this for some time while preparing the Engine this summer.
I have not started searching MBWorld yet but I am sure there will be some good ideas as well.
Cheers, Gator
