W209 M113 v W208 M113
Old Dec 15, 2016 | 12:41 AM
mickey13's Avatar
1999 AMG C43
Question W209 M113 v W208 M113
Can you guys tell me about the differences in the W209 (113.988) v the W208 (113.984) engines? powerbands, reliability, etc etc? prefer one over the other? aftermarket mods?
Old Dec 15, 2016 | 06:35 PM
tw2's Avatar
tw2
I thought they were the same in terms of what you are asking, power reliability etc. I am pretty sure the front end is slightly different in terms of water pump, oil pump, pan and hose/pipe routing. Also there was a change in ecu between the early w208 and later w208 engines, I don't know about the w209.
Old Dec 15, 2016 | 10:14 PM
mickey13's Avatar
1999 AMG C43
well i have read that the last two 208 model years were updated in respect to me2.8, meaning they changed the connectors on the engine harness. there also seems to be an idea that the last two 208 model years also received a bump in compression, but i'm wondering if the bump in compression didn't come until 209.
so i have also read that the power bands between the 208 and 209 are different, where the 208 falls flat the 209 picks up a bit. my understanding is that the 209 has a different cam profile and strengthened heads. hoping you guys would have more details for me, regarding these things. and maybe also regarding differences between available aftermarket upgrades
209 comes with a bigger TB?
Old Dec 15, 2016 | 11:40 PM
tw2's Avatar
tw2
Yes that is correct with the newer ECU, faster processor, I think larger fuel/ignition tables etc. I can't help anymore sorry but I can say that the top end of the M113 is greatly hindered by the restrictive stock headers/downpipes so as long as you do mid or long tube headers then I think you will be pleased with the powerband regardless of the M113 variation. I would find the latest M113 available, things usually get better over the design life. Is this for a C43 swap?
Old Dec 15, 2016 | 11:49 PM
mickey13's Avatar
1999 AMG C43
yeah i bought an 02 208 55, but im thinking about shelving it for a 209 i found.
Old Dec 15, 2016 | 11:54 PM
MarcusF's Avatar
2002 CLK430
The U.S. didn't receive the CLK55 until the 2001 model year, so all CLK55s have ME 2.8. The bump in compression came with the 209. The 55 TBs are all the same part number, so they're the same size, but I think they've been NLA for a long while. The ME 2.8 430/500 TB is the same diameter as the OE 55, but a different part # than the OE AMG part. The NA 55 heads are all the same. In fact, it's the same part number as the 500; a 2020 and 2120.
Old Dec 16, 2016 | 12:05 AM
mickey13's Avatar
1999 AMG C43
have you ever heard of the evo engine?
http://www.mobilverzeichnis.de/merce...orenuebersicht
on epc, i only see 209 amg designation 113987 not 113988, but i see the 171 amg designation 113989
Old Dec 16, 2016 | 12:19 AM
mickey13's Avatar
1999 AMG C43
you're right though. all the heads are the same part number... really strange
edit: camshaft and spring part numbers are different on the evo designated engines
Old Dec 29, 2016 | 04:55 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Suspension(better) and I think the tranny is different in the w209. Better exhaust system and klemann makes nicer headers for the w209. W208 lighter and feels faster. Both cars are reliable.
Old Dec 29, 2016 | 06:08 AM
Chappy's Avatar
AMG
^^^Great to see you and Marcus on the boards!
To the OP - My (limited) understanding is the engines are virtually the same except for the following for U.S. Spec versions:
-Stock HP rating was 362 on the 209 vs 342 on the 208
-Stock torque was the same at 376 lb-ft
-Engine management was newer generation on the 209
-Rev limit was slightly higher on the 209
That said, in practical terms, the street/track performance was nearly identical. Many dynoed within 10whp of each other.
Good luck with your build!
Old Dec 29, 2016 | 11:36 AM
ProjectC55's Avatar
Da Chapster! Good info and longtime my man!
Old Dec 29, 2016 | 12:25 PM
MouTine's Avatar
'14 E500 Coupe
Cr, cams and ECU tune. Those three things make the power diffirence between 208 and 209 55's.
Old Dec 30, 2016 | 02:57 PM
Chadzu's Avatar
2001 Clk55 AMG
Is there any definitive proof that the 209 55 motor actually has more compression and different camshafts than the 208 55?
I haven't been able to find verified tested numbers.
Old Dec 31, 2016 | 05:26 AM
MouTine's Avatar
'14 E500 Coupe
Nope at this point sorry. But when I sold my 208 55 and before bought my 209 55 I made lot of investigations and came by datasheet that says cr is 10,5 versus 11. Can't find it now with quick google search.
And if you think about it those three thing are only factors that can do 20hp power diffirence in othervice same kind of engine.
Old Dec 31, 2016 | 01:54 PM
Chadzu's Avatar
2001 Clk55 AMG
The 209 has better exhaust, and a higher redline. Which can account for hp numbers.
And it isn't uncommon for a manufacturer to stretch the truth a little to sell the new model.
I'm not trying to start an argument or step on anybody's toes, but I sure wish we could get past the he said she said thing.
Old Dec 31, 2016 | 04:01 PM
Chappy's Avatar
AMG
Back in 2004, I organized a day at the drag strip. The stage was set: My bone stock W208/55 vs a W209/55, also stock. "Rafi" backed out at the last minute so I guess we'll never know lol....I still have my W208/55 but have a new toy that is scratching the performance itch (for now.)
Old Jan 8, 2017 | 01:31 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
I have read elsewhere in the forum W209 cams are preferred.
Swapping then questions the tune. If I locate a set reasonable we can get some data.
I am heading for the dyno this year.
Gator
Old Jan 10, 2017 | 06:56 PM
kb24forlife24's Avatar
None for now
If you find a second set of W209 55 cams, hit me up Gator
