Esp defective visit workshop
Old Apr 20, 2017 | 05:53 AM
Clk55amg2004's Avatar
CLK55amg
Angry Esp defective visit workshop
Hi all,
Hope you can help me.
My car is a 2004 clk 55 amg 80000km, everything was fine until last week.
I was driving it a it just turn off.
I've took it to a garage and they are not sure what it is, but probably is unit control.
They say some times the car is fine and for no reason it turns off.
Any guesses??
Thank you
Old Apr 20, 2017 | 09:09 AM
HCUBED's Avatar
W209 2003 CLK55 Coupe
Mine had the same message...turned out to be a faulty yaw rate sensor.. Replaced it, and all is well.
Old Apr 24, 2017 | 09:18 PM
fixedhalo's Avatar
2002 CLK55 Cab & W213 E300
Had same message, turned out to be the brake light switch.
Though this could be anything from an yaw sensor, to a wheel speed sensor... Best bet is to find someone with an SDS machine to diagnose what the real issue is.
Old Apr 24, 2017 | 10:37 PM
ItalianJoe1's Avatar
2003 CL 600
ESP message shouldn't turn the car off though, there might be something else going on. Have you replaced the crank position sensor (CKP) recently?
It's common to get faults in other modules when a required input is missing, in this case, the ESP is looking at engine speed via the CAN, if it's not there, it sets a fault in the ESP even though there isn't an actual issue with ESP, but it can't do it's job if it isn't getting all the information it needs.
A bad CKP would explain the random shutting down, and they don't always set a P0335 code when they fail.
