Fired up my Turbo Deisel today
Wife and I took the CLK 55 down to Tampa prior weekend for a concert. I like Joe Walsh She likes Tom Petty it worked out perfect.It was relatively a short trip around 1.5 hr but what a rump roast.
It was fast and furious but I was longing for the ride of my W124 which had hydraulic suspension. It literately turns the road into a piece of glass and all are fresh when arriving to destination.
My W124 Wagon has a few problems but I am giving in. It was worth the ride. Trans leak and PS leaks took it off the road back in 2012. Found my AMG.
Connected the battery today and repaired a couple of wires, It cranked up after half revolution. The turbo swills loud and the idle is like new.
These turbo diesels under full boost were 400 hp but it took a while to get there. Aneroid and pump nozzle tweaking made the fun and efficient but not as strong as the later Gassers.
Thought I would share my thoughts on a missed Mercedes Classic. I am going to bring it back though. There is no car that you can buy that rides this good.
Sitting for some time cranked up and turbo spooling like new.
Chime in if you have a special ride like the W124 TD that keeps you in the past "Ian Anderson"
All the Best, Gator
Never considered going smaller which makes sense. I have a OEM Garret on it now which has a larger flow I/O than the optional KKK Mercedes OEM Turbo charger. In vintage threads on dynoed cars the KKK performed better.
One incredible note about this car. It is a survivor, It can be push started in 2nd gear, and will get you home with no alternator charge at all. I did it one morning after work. had just enough battery to start the engine. There is a ECU for idle circuit only no electronics. I had a clutch driven fan at the time.
I have read about super turbo diesel built by the Fins and they went larger in the turbos but a smaller one might make it more desirable for commuting.
Best, Gator
On your turbos I was really giving you two thoughts, a) you could replace the current turbo with a smaller one to come on boost sooner or (b) keep the cyrrent turbo and add asecond, matching smaller turbo to your current setup resulting in a compound setup. You get on boost sooner this way and lose none of the top end of your current setup.
The last CDI L6 24 valve shipped to the states advertises 450 hp on the engine ID tag.
I believe early ratings like my own wer measured @ the flywheel and not the rear wheels like we do today.
These are a lot of fun to watch and turbo diesel is an extremely well engineered engine ready for almost anything.
Mercedes will stop shipping Diesels to the USA soon from a lot of political controversy from VW alleged Code tampering. I worked for VW dealership in the 80's and did much calibration of the CIS injection systems. If any coding poor coding was done it was likely from the dealership. as ordered.
I am not giving up my AMG for the Diesel but it held a special thought when so little effort was required to wake it up.
A very special Mercedes Turbo Diesel can be viewed in the old movie Driven W Sly Stalone.
I have some real good links to the folks in Finland who pioneered the most potent of them but not on this PC
Enjoy.
Looking forward to watching the Indy Race and the Nascar Coke 600 on Sunday.
I have not reviewed the car maker line up but there was no Mercedes last year as Formula 1 is more refined world class racing.
My Blessings to all soldiers past and present this coming Memorial day.
Cheers
