Can't find cluck from front end
W208 2 started Clunking on me to be expected. My driveway is hard on ball joints as well.
I would not let it disturb travel plans unless the car pulls or shakes real bad,
Cheers, Gator
jack the wheel off the ground grab the wheel at 9 and 3 o clock. rock back and forth if play is evident the culprit is found in steering drag link, idler arm or tie rods.
Ball joints are different. With the car jacked up get a buddy wife, dog etc to (gentle) rock the wheel from the ground to up position.A 2x4 placed under the tire and slow pry the tire upward.
Inspect the ball joints for movement. They should follow the movement of the control arm. any excess movement in the ***** socket will be evident in this test.
Cheers, Gator
Cheers, Gator
