sagging glove box lid. Fix suggestions?
Old Aug 27, 2018 | 06:45 PM
MikeNSX's Avatar
2007 CLK63 AMG
I've noticed that the glove box lid doesn't close tightly and this causes misalignment which is noticeable. I can push it closed farther and it aligns perfectly. I've noticed this on many pictures of CLK's so it must be a common failure. The cause is that the inside striker plate made of black plastic is loose and not tightly held in place. I see no screws to tighten to fix the problem. My fix would be to put JB Weld into a syringe and neatly glue the striker plate in place.
Are they any better ideas on how to fix it correctly?
Old Aug 27, 2018 | 08:39 PM
MikeNSX's Avatar
2007 CLK63 AMG
Originally Posted by Plutoe
Yep define the part that is used to slowly lower the lid------purchase the part------install the part------its a very simple process!
Thanks.. but the glove box door lowers fine. The problem is the loose striker plate that is suppose to hold the door closed. I'll snap a pic of it tomorrow.
