W208 CLK55 chassis codes - 208.374 / 208.474 what is the difference?
Old Oct 24, 2018 | 11:55 AM
j-mo's Avatar
2006 E55 AMG, 2019 BMW M240I xdrive coupe, 1969 Mach 1 Mustang
Hello,
I am trying to find front shocks from my W208 CLK55 and it is tricky. I bought Sachs OE ones that were too short. I see some listings with the chassis code. My CLK is 208.374 but some of the shocks are for 208.474. Can someone tell me what the difference is? I thought 208.474 might be convertible but I then find coupe listings showing either chassis code.
thanks!
Old Oct 24, 2018 | 12:20 PM
loggato's Avatar
1999 SLK 5.5L 6-speed, 1993 300 SE
How short are they? I believe some shocks are spec'd to be paired with lowering springs. Also my guess is some models came with different spring pads which may be the difference.
Old Oct 24, 2018 | 01:17 PM
j-mo's Avatar
Thanks. The Sachs OEM ones I bought were about 2-3 inches too short. I know the sport ones from Bilstien are to be used with lowering springs. These I bought because they said OEM.
I actaully posted about it here -
https://mbworld.org/forums/clk55-amg...hort-help.html
Old Dec 9, 2018 | 04:18 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
374 is coupe, 474 is Cab shocks should be the same
Old Dec 10, 2018 | 11:33 AM
j-mo's Avatar
Thanks, that is what I thought for the chassis code.
The shocks are different though. They have different parts numbers. I can only assume the cab ones are different or shorter.
Old Dec 10, 2018 | 03:45 PM
C280 Sport's Avatar
MB’s of all kinds.
Coupe vs Cabriolet.
