Just another W208 M113K Swap
Big job for a customer, figured id share some pics.
If you have Instagram follow me @euroworksfl
And here it is running
I believe only have to swap over the W208 pan and pump. W211 has staged high volume pump with custom screen.
Alternative for high Hellcat HP applications would be an external dry sump and external race pump, Not that difficult to plumb into the W208 pan.
Cheers, Gator
Earlier threads and years always lead people to just say "too hard" and install a Kleeman. Well it's a legit option if stock m113k levels of power are your ultimate goals. I have both a Kleeman and a couple m113k. In today's market adding $14k in a Kleeman to a $14k CLK55 is hard to justify for 500hp. This is no slam on Kleeman, but as our cars have depreciated, the general performance car industry has partially caught up.
Today, I think the S55 and CLS55 make great donors. And the C55_Slk55 and CKk55 are lighter simpler and cheaper to maintain and hot rod.
As Eurowork has suggested you need a hybrid oil pump and possibly hybrid oil pan. And I'm partially convinced some one w Star in the end to correct some errors, edit TCU, adjust for diff ratio as I'd prefer the Clk/C55 gear for hot rod. Exhaust is a non issue, HE needs to be selected correctly for clearances.
Euroworks....if only you werent so far away I'd be at your door step on a free day. Eurocharge offers similar feats and results but the cost envelope is cloaked in a foggy haze.
Thanks again for posting!
