W208 CLK55 Antenna cover - paint question
Old Aug 15, 2021 | 11:35 AM
j-mo's Avatar
2006 E55 AMG, 2019 BMW M240I xdrive coupe, 1969 Mach 1 Mustang
Hello,
My antenna cover has been trashed for a while so I finally bought a new one as I have repaired the rust on my CLK. Apparently it comes unfinished even though this ebay add showed it painted black. This is any OEM part.
Anyway, I can bring it to my body man but was also thinking this would be simple to paint. I wanted to ask since it is going onto my freshly painted car. Should it be primed? Should I just get some gloss black spray paint for cars? Any recommendations?
thank you!
Old Aug 17, 2021 | 09:18 AM
MattCordell's Avatar
C43 AMG with a tune up
You need to prep cover with primer for paint to stick otherwise next time you wash your car with a water jet pressure you will blast the paint off and you need to paint it again.
Therefore, first spray plastic-rubber primer and let it dry for 24hrs before you apply paint the next day.
Finally when it's done you apply clear coat
Old Aug 18, 2021 | 04:24 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
I have no doubt you can do it yourself, but I would highly recommend you have a professional paint shop do it to avoid any mis-haps. It's a small piece and it won't cost a lot to paint.
