AMG euro-spec springs - W208 - First Impressions
Old May 16, 2007 | 08:00 PM
  #176
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Originally Posted by JLee81
I think I will try to clarify some stuff here.
The part numbers you have are the correct for the european 208 CLK55 AMG.
USA version of CLK55 AMGs have different part numbers for the springs and these changes along with the options you have on your car and the designated model number within the CLK. But most importantly, you will have to order a new set of pads as well to get more low ride. or you could just use the pad to lower 0.5 inch from your current spring. What is it that you want? How much do you want to drop your car?
I dissagree partially. You will find that some W208 CLK55's are using different springs than each other with some using the so called "Euro Spec" springs as well. This was definitely the case with the C43. Some of them use different springs and pads. The whole MB spring thing is crazy because the so called "Euro Spec" spring thingy for some cars are actually the Stck springs on the W210 E class wagon and other models. The thing is that alot of these springs are completely swappable between cars. That's why I think the name Euro Spec Spring is a tad funny to me.
Old May 16, 2007 | 08:07 PM
  #177
ProjectC55's Avatar
Originally Posted by AMGEEZY
Well I I talked to Steve and he confirmed those part #'s. He told me he can get me the rear for $150.00. He said he could get the fronts as well, but they were available in the USA. So I am going to order the front today from my dealer and order the rear from Steve. For a grand total of $318.00. I knew there had to be a cheaper way to get these springs. Not that I didn't trust GERT, but with the exchange rate it is just out of control.
I want to drop the car an 1" at least, Plus I just don't like the way the H&R's look, I feel they drop the car way to much and make it look ricey. I'm sure the ride with H&R's suck too. Way to rough.
318.00 is alot of money. I need to speak to Steve because I posted in this thread somewhere I believe that the whole set was available for about 240.00. I listed the part #'s with the price. So if you guys are willing to pay top dollar for these things which are regular MB springs go ahead. Or just give me a donation Send me the part#'s again and I'll 100% confirm that for you.
Old May 16, 2007 | 08:12 PM
  #178
Holson's Avatar
18 G550, 24 EQB3504M
I want to lower my CLK55 just a tad (to separate it further from the Hummer ).
I'm gonna ask my mechanic about installing thinner pads all around (dropping it at each corner by the same number of 'ticks').
Interesting to know that it uses W210 springs for the front however - do they even share the same suspension?
Old May 16, 2007 | 08:43 PM
  #179
ProjectC55's Avatar
May not make mch of height difference depending on the srings. I went thru #'s 1 thru 4 on my C43 and the main difference in the height of the car will be more affected by the springs. Don't waste your time guessing and spend cash for nothing. If your car is high then you can do like MBenzman and myself did by cutting a coil off the OEM springs or just getting the so called "Euro Springs" and playing with the different pad sizes. I will post pics of my car after this wknd. I want to take the #4 pads out the front and replace them with # 3's. Then i'll have #3's in front and #4's in back.
Old May 17, 2007 | 01:26 AM
  #180
AMGEEZY's Avatar
2001 CLK55
The rear springs for the CLK55 are definetaly not available in the US. They are a 208 part #. I have checked with my dealer and they are not available in the US. The fronts on the other hand are definately 210 springs. They are available at the dealer. They go for $160.00 for the set (2). Now the Fronts from Steve are $150.00. If you think you can get them cheaper let me know, but I doubt it. But if you can get them for $240.00 Ill be the first one to buy some. When everyone says euro spec, I think they mean a Euarpean CLK55, it definately sits lower due to the Bumper regulations in the US.
Old May 17, 2007 | 05:18 AM
  #181
ProjectC55's Avatar
I'll chk for you first thing this morning.
PS You do know that the C43 and the CLK 55 share the same suspension.
Old Jun 16, 2007 | 03:04 PM
  #182
AMGOODNESS's Avatar
03 CLK 55 AMG, IMCO muffler/Magnaflow tips, KW V1 coilovers, 19" Petrol Metrix Wheels
ok definitely want to lower the car. i have read this entire thread (long, confusing, and exhausting) and i still dont know what the best course of action is here. like most of you i just want to drop an inch without having to do the end links and camber crap.
i am thinking that swapping out spring pads will only marginally drop the car. plus does the mb dealership have various pad sizes readily available? if they do then the best bet might be to get the h&r's and thicker spring pads.
i have a W209 CLK55 AMG. still not sure what to do so i may have to chill and let this play out a bit more.
chappy i will ask you one question. did you compare the size of the springs you got from Gert with the stockers you took off your car?
Old Jun 16, 2007 | 05:07 PM
  #183
Chappy's Avatar
AMG
Yes, they were shorter.
Old Jun 16, 2007 | 05:42 PM
  #184
Stiggs's Avatar
2003 CLK55
I was in your same place a while back. Only thing that stopped me was the price at the time and those damn spring pads. I had no idea which ones to use and the place I was gonna have them installed at didn't have any either.
Nothing is easy to mod on this damn car! LOL
Old Jun 19, 2007 | 04:12 PM
  #185
AMGOODNESS's Avatar
hopefully the mercedes dealership will know which part number is for the 8mm spring pads. i think i am going to also pick up the 12mm pads. i will try the h&r set-up and just go trial and error from there. if anyone knows the part numbers for the spring pads that would be a great start.
Old Jun 24, 2007 | 01:17 PM
  #186
Stiggs's Avatar
2003 CLK55
Man, after re-reading this thread again it makes me really want to get the Euro Spec springs again. I've decided to keep my car for now so maybe its time to give this another shot. Gert...here I come...again! LOL
Old Jun 25, 2007 | 12:07 AM
  #187
AMGOODNESS's Avatar
seriously anyone know the spring pad part numbers?
Old Jun 25, 2007 | 06:39 AM
  #188
Stiggs's Avatar
2003 CLK55
My plan is to call up my dealer and order them. I will get 5mm rears and 9mm fronts. I'm assuming they will have all the different sizes there or they can order them for me. I'm gonna try again to get them installed at my dealership. I have a new service rep since the last time I tried.
Old Jul 2, 2007 | 07:23 AM
  #189
Stiggs's Avatar
2003 CLK55
Is Gert still around? I e-mailed him over a week ago but still no response?
Old Jul 3, 2007 | 01:09 AM
  #190
AMGOODNESS's Avatar
stiggs post up some part numbers for the various sizes if you dont mind.
Old Jul 3, 2007 | 07:19 AM
  #191
Chappy's Avatar
AMG
His website is still up....
http://www.carnewal.com/
Old Jul 3, 2007 | 07:30 AM
  #192
Stiggs's Avatar
2003 CLK55
OK...I'll try him again.
Once I get the springs (if I get the springs) I will try to see whats stamped on them.
Old Jul 3, 2007 | 07:31 AM
  #193
Chappy's Avatar
AMG
.....and when you do, please highlight the fact that they would be for the W209 CLK55 as opposed to the W208 CLK55.
Earlier in this thread, AMGEEZY wrote:
"The rear springs for the CLK55 are definetaly not available in the US. They are a 208 part #. I have checked with my dealer and they are not available in the US. The fronts on the other hand are definately 210 springs. They are available at the dealer. They go for $160.00 for the set (2). Now the Fronts from Steve are $150.00. If you think you can get them cheaper let me know, but I doubt it. But if you can get them for $240.00 Ill be the first one to buy some. When everyone says euro spec, I think they mean a Euarpean CLK55, it definately sits lower due to the Bumper regulations in the US."
Any follow up to this?...what are the part numbers (for the benefit of others here) and what did you pay?
Old Jul 3, 2007 | 11:55 PM
  #194
Stiggs's Avatar
2003 CLK55
Will do.
Old Jul 5, 2007 | 05:26 PM
  #195
AMGOODNESS's Avatar
stiggs i need the spring pads #
i am likely to go with h&r or eibach in terms of springs.
Old Jul 5, 2007 | 07:08 PM
  #196
Stiggs's Avatar
2003 CLK55
I ordered the pads through gert so when I get them I'll look for a number. Its gonna be 7 days at least before I get them. I don't know if these part numbers will be the same with US dealerships since I'm ordering everything from Gert. I will post them anyways.
Old Jul 5, 2007 | 07:20 PM
  #197
AMGEEZY's Avatar
2001 CLK55
Here are the part #'s W208
Front Springs 210-321-32-04 Available at your dealer or oempartsdirect.com $173.00 at my Dealer
Rear Springs 208-324-02-04 Not available in the USA. Email Gert or Steve. $210.00 shipped from Steve
Pad Recommendations for Euro Springs Part #'s
Front 210-321-02-84 2 Bump I paid $8 for both
Rear 210-325-01-84 1 Bump I paid $6 for both
I have everything but the rear springs. Just waiting for them to arrive, they should be here soon. I am hoping to have everything installed next week. I also bought some new Bilstein HD shocks, Poly Bushings, and Ball Joints. My car has 70K on it, figured since I was putting new springs, might as well put new Shocks, Bushings, and Ball Joints. Will post pics once I'm done.
Gert sells the complete set (Springs and Pads) for 358 Euro which translates into $486 USD. I paid a total of $397.00 for everything. It took some research but I saved about $100.00, doesn't seem like that much, but that extra 100 paid for my Ball Joints and Bushings.
Old Jul 6, 2007 | 07:26 AM
  #198
Chappy's Avatar
AMG
Excellent info, thanks for sharing.
Old Jul 6, 2007 | 12:43 PM
  #199
ashutt's Avatar
2005 SL600 by SPEEDRIVEN
Bilstein HD instead of the Sport Line?
The AMGs came with the Sport line. That being said, why did you go with the HD instead of the Sport line of the Bilsteins? Although they are valved the same, the Sport shocks are shorter for the more lowered CLK- according to Bilstein. This may be more applicable as you are lowering your car even more now. Anyway, just wondering what your thought process was?
Old Jul 6, 2007 | 06:58 PM
  #200
AMGOODNESS's Avatar
I will go to the dealer and see what I can find out. Thanks for the part numbers, they will be a good start.
