My dealer wants $990 for a front-end brake job.
You want to stick to OEM AMG or would you consider Brembo or Stoptech or one of the many other companies in stock sizes or perhaps a BBK (Big Brake Kit)?
what would you suggest in getting.,in the brake pads and rotor?
I want to stay with stock SIZE.,..
btw. how is the C32 AMG brake compare to our w208 clk55 brake.,
which one has a better stopping power
Interestingly, the Porsche Boxter stopped in 112 ft.
I don't care what parts I replace them with as long as it's not K-mart parts.
(Rotors used to be around $400 each so you should be happy. A brake job for the front was $1100 just for the parts.)
$270 for labor... a bit high, but not out of line with what most dealerships charge for labor.
-s-
-s-
even my dealer quoated me 220 for pads, 600 with rotors included
Amil, your dealer is only charging $380 for BOTH rotors?
What gives?
What gives?
Read Scorchie's post above....prices have come down, plus our setup is using a multipiece rotor as opposed to the brembo setup found on C32s and W209 CLK55s.
-s-
Thank you for clearing that up!
-s-
What changed on the 2005 CLK/C55 setup vs. the '03-'04 parts?
Not playing into the high cost of the fronts, but the rear discs are ventilated again.
-s-
-s-
