Pros & Cons: Larger Tires on Standard wheels?
Is there any advantage in using larger tires than the standard 225/45/17 for the front & 225/40/17 for the rear on the standard wheels?
What is the widest tire the stock wheel will handle both front and (most importantly) rear?
I have been considering this too. I think it would look nicer having wider tires in the back. They look pretty whimpy at 245/40. It should grip better. It may slightly throw off the balance from understeer to oversteer for example or something along those lines. I do not plan to use my car at a track and will rarely if ever have it handling at 10/10th's of its maximum so that point is irrelevent to me.
For the standard rear wheel - 8.5 J X 17 - the max. width is 255.
As per many charts, incl. this Potenza S-03, the best rated tire according to the forum sponsor Tirerack.
http://www.tirerack.com/tires/Spec.j...+Pole+Position
It's strange.
I listed this question under the "Wheels & Tire..." section and so far ZERO response.
Increased tire WIDTH is the most inexpensive way of improving appearance & handling: $60.- per set of tires!!
This question really depends on your driving style. If you're going to go with 19's it will look really nice but watch out for them potholes. One serious hit and that's an expensive wheel/tire to fix.
Can one use wider tires on the standard 17" wheels?
Standard front tires: 225/45/17.
Increase to 235/45/17?
Standard rear tires: 245/40/17.
Increase to 255/40/17?
My question relates to wider tires on the same stock wheels, NOT larger wheels.
I would suggest that this question be posted on the tire forum of this site. Luke, of TireRack, is very good at answering questions like this one.
That's precisely what I thought and posted there first. Only one response...
https://mbworld.org/forums/showthrea...&threadid=9752
I think you'd have to go 235/40/17 and 255/35/17 if it's available. This way, the diameter won't increase too much.. Less likelihood of ESP/ABS/speedo calibration getting screwed up. Also, if you have Comand, you'd have to re-calibrate; but that's easy.
The revolutions per mile are 10 less for front and 10 less for the rear: 833 v 823 and 840 v 830.
Changing tire sizes will affect the handling characteristics of your car. Dont play around with them.
If u change to larger rims like 8x18 and 9x18, then tire size should be 235/40/18 in the front and 265/35/18 in the rear.
So, Karl, I'm beginning to think you're on the right track for traction upgrade; rather than the disastrous path I took on my 55 with the 19's. I'm sure you've read about my woes.
So why not 265's in the back? The 235s will probably be just about flush with the fender lip, but the 255s will be too fan inside the well?
Sorry, I was never good at math, especially METRIC math
So, I decided to go with the
235/45/17 front tires on the standard 7.5 J 17 ///AMG monoblock rims and
255/40/17 rear tires on the standard 8.5 J 17 ///AMG monoblock rims.
The Bridgestone Potenza RE730 tires have a treadwear rating of 300.
The original Michelin Pilot Sport tires have a treadwear of 220.
Here are the specs for the RE730:
http://www.tirerack.com/tires/Spec.j...a+RE730+Gen.+2
