CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
oil change?
Old Sep 15, 2008 | 10:22 AM
BLACK SERIES 63's Avatar
CLK 63 Black Series
oil change?
when should the first oil change for the B.S be?
thanks in Advance
Old Sep 15, 2008 | 11:42 PM
JDB's Avatar
JDB
CLK63 Black Series
AMG recommends that the engine oil be changed at 10,000 mile intervals.
They have just updated the recommended engine oil to Mobil 1 5W-40W.
The oil in the limited slip differential (LSD) should be changed at 1,800 miles.
When the gear oil is changed, I believe a new drain plug should be fitted (at least that was part of the process at the dealership when I had my gear oil changed).
JDB
Old Sep 16, 2008 | 12:00 AM
ohlord's Avatar
Dealer went back to 0w40 mobil1
the 5w4o is now being used in the diesels.At least that is what I heard from Mercedes.
Old Sep 16, 2008 | 12:50 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Mobil1 5W-40 is now official from AMG recently posted in the PL for 63 engines.
Mobil1 0W-40 will work as well.
Don't fret
Old Sep 16, 2008 | 09:02 AM
AMG Dictator's Avatar
CLK Black
This is exactly how all the BS starts...... JDB and Jon are correct. 0 or 5/40 for the Black will work as stated by AMG on the Private Lounge.
Do you own a Black Series? Don't add to the confusion
Old Sep 16, 2008 | 08:25 PM
user z478747's Avatar
08 SL55
Let me start by saying that I am most certainly not an oils expert but followed a discussion on the Rennlist 928 discussion board. Doug Hillary is located in Austrailia and IS an oils expert. I took his advice and used Delvac 5-40w in all my 928s for the past 4-5 years and liked the charecteristics of this oil vs. the 15-50w Mobil 1 I was using. I will switch to it in the CLK BS too. If you care to read his update from the extensive testing he has done click this link: http://forums.rennlist.com/rennforum...d.php?t=359716
BTW, I will not let my oil go 10k miles, rather I plan to change it at least once a year if there are no track events during that 12 months, more frequently if I ever get it on the track.
