What's the Tire of choice to replace Corsa's
What is everyone planing on using for Tires... being the OEM Corsa's are done...
The Dunlop track tyres developed for the C Coupe Black Series will be out soon btw , for those looking for track rubber .
Also toyo 888 fit ( albeit again with 295 on the rear ) .
Can you guys get corsa Trofeo in the us ? These ( and Corsa Race ) are even better than the oem corsa system , but not cheap .
Next year plan to get new skins, for AutoX track, be fine with the stock Corsa for by BS, store them in bags downstairs when not in use. Also spare set of original (heat cycled past their time/5 year old next year) tire/rim downstairs for street as I love using very little effort/engine noise/tire squeal to drift (5-20 degrees) around quite often, and not attract too much po-po (or tattle-tale) attention
.Thanks jrcart!
.Thanks jrcart!
Thanks very much for the lead jrcart!!
Same goes with the Michelin Sport Cups, unless you are running these tires at the track I see no point in buying a set for street use.
I'm running Nitto INVO's and they are working just fine. I ran them on the track at Spring Mountain ... again, worked just fine.
G
Perhaps this is the difference in Mercedes and Porsche owners.
All my Porsche friends pull their Cup tires off at the track to run R6's but they still show up with Cups and leave with Cups.
Just sayin
Just sayin
G
From a performance standpoint I bet it is. Most of the modifications on the CLK Black will let it better stand up to long term track use. Additional stiffness, adjustable suspesion, more cooling.
I would be willing to bet that the single biggest performance enhancer on the CLK Black is the Cup tires.
From a standard set up in suspension to the adjustable ones on a track like Laguna Seca and I bet you can make the car a second to a second and a half faster. Additional stiffness over the standard car is good for what? perhaps a second in the hands of a professional driver?
Change the tires from a 180 tread wear to a 60 and you probable pick up 3 to 4 seconds a lap.
Is this point really one to argue?
For tire replacement, I went with best of breed street tires since the R-comp Corsas were costly and really hard to find... and most of my driving is not on the track. While the Corsas may be 10% more fun when you're at the limit, if you're pushing that hard on the street, you're a lot crazy.
I went with PS2s. I'd go with the Super Sports now.
