New clk63 bs owner in need of advice
You are right, this car is amazing.
For the parktronic, I heard it was done on a CLK BS in europe. The electronic is the same as non BS CLK so no worries about OEM partronik retrofit, except you need tu cut in the front and rear bumper.
Sorry I understood partronik
when you where speaking of radar detector (forbidden in europe)
For the TPMS, it seems to be on US CLK BS but not on Euro Spec.
Weistec have done several CLK BS and offer some upgrades. For example, on my CLK BS I have :
- Oil /Air separator,
- Aluminum Billet Idler Pulleys,
- Aluminum and bigger capacity Transmission Pan
- Rear Differential Mount Bushing
As for the TPMS, I've owned 2 US CLK BS's and neither had that option. I think it depends on when they where built.
As for the ESP, it is sensitive, if you don't like that, just turn it off.
GL w/the new ride. Post pics when you get a chance.
I have never had any issues with throttle cutting during turns and I have never turned off traction control , I'm scared
The problem in the end was the rear sway bar bushings were worn. I replaced the rear sway bar and the problem went away
