NEW CLS 500 OWNER HELP!
Recently bought a 2006 CLS 500 w/ 120k Miles.
Just changed the ac compressor and 2 faulty spark plugs.
But I get get a slight shake/vibration when i stop then it goes away.
I also would get a quick vibration when driving.
its a quick shake/vibration.
Ive tried to search the forums but couldnt find anything to see what I can check or do, really hoping to get help from the forum. The car is for my wife and I dont want to put her in a bad situation when driving the car.
thanks in advance!!
thanks for the reply.
check engine light finally went on and it read misfire cylinder 1 and 6.
but these are 2 spark plugs and coils we just changed.
also as i was driving today the car died on me as i was stopped.
any guess what it can be?
thanks,
i surely will post what happens.
you know anything about to camshaft problem I've seen pop up several times with the cos 500?
Since you are getting cylinder misfires, different issue, but take it in to get it fully checked. Don't guesswork the issue. Coil pack? Plugs faulty? It could be a several things.
If your car has 120K, I don't know why you would replace only two spark plugs. Replace all 8 plugs and coils. Also check if there is any coolant in the oil.
