LoMo M1 Lowering Module Installation Help!!!
Old Jan 28, 2015 | 11:34 PM
Birlionaire's Avatar
2013 CLS550
Arrow LoMo M1 Lowering Module Installation Help!!!
Hey guys,
I was trying to install the LoMo M1 Lowering Module myself and everything went smoothly until the last step where Im suppose to locate the CAN wires and "T" in to them.
The instructions told me that the CAN wires are a yellow wire and a green wire that are twisted together and that its ran along the passenger door sill under the carpet.
Has anyone ever installed this module yourself? Or do you know where I can find the CAN wires?
Any help is well appreciated. I will post pics of my car once I install the module.
Thanks for taking the time to read my post.
Old Feb 12, 2015 | 02:12 AM
flossmanm3's Avatar
ML63 w164
look for the obd plug, shud be on the underside panel of the steering wheel, you should be able to find the wires there as well.
Old Jun 27, 2016 | 12:05 PM
Quick Silver's Avatar
2019 CLS450 4matic, 2013 CLS550 4matic (totaled), 2005 C55 (traded), & a Ford F150
Originally Posted by Birlionaire
Hey guys,
Did you use the "Quickconnect Harness"? How hard was the install?
Old Sep 9, 2017 | 03:28 PM
edwsn2005's Avatar
2014 CLS 550
Did anyone ever come up with a solution for where to place locate the CAN wiring? I followed their instructions, but I can't get the unit to work.
Old Sep 9, 2017 | 06:12 PM
Hopefully I successfully attached picture showing CAN wires coming off lowering unit (in passenger footwell) between the two big connectors. I tried to upload as a picture but couldn't from my iPad. Also when I installed mine I used 14-18 gauge T connectors and it wouldn't work so I went out and bought 18-22 gauge and then it worked perfectly.
Old Sep 11, 2017 | 07:17 AM
edwsn2005's Avatar
2014 CLS 550
Thank you for your response. That helped a lot. I still can't get to unit to work. I'm pretty sure that I have all the right connections, but I may not be receiving any power to the unit. I've read that the power wire coming from the Lomo M1 harness, may not be pierced at times, so that I may have to wrap it around the OEM power wire. Have you heard of anything similar happening to anyone else.
