Racing Brake CLS Upgrade Package?
#51
What year and model of caliper is the one in green come from?
#53
00 C200 & 00 C55 & 06 SLK55
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/283x283/0054203620_rdr_1e32a21d8290809fca7530f10d78397f69271991.png)
Yeah sure W219 & W218 uses the same drum dia., which is (180x25),,
but can't assure the fitment of parking shoes, due to differ shape of the parking shoes & shoes mounted base (in dust shield)..!
-;ZAYED;-
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/283x283/2304200320_rdr_ec4716c00cbf30c9d11a964e0e32821c7faf5663.png)
#56
I am sure the size of the drum is 180mm. I just look up the drawing from Brembo and ATE. However, I am not sure whether they have a different mounting position of the back plate or not.
#57
Yeah, that's why prefer to get "W219" shoes,,
but before that, just get "W219 Cls63" Rotor & try it with "W218" shoes, it may fit,,
it's really not big deal..!
#58
Agree. Since he said he already got the calipers, just try it as long as the caliper's mounting hole is the same. However, if he need to search for the caliper, I will also suggest to go with the w218's AMG setting because it use the same brake shoe on both car. It means that it will fit without any problem.
#59
Yeah, agree with you for sure,,
done many brake upgrade with many differ M/Y before,
just around 5 years ago, installed "W204 C63" F/R calipers & Rotors into "W219 Cls350",
and "W211 E63" F/R calipers & Rotors into "W218 Cls500", Fronts was bolt-on, but Rears not..!,
had to change the dust plate & parking shoes, everything else was fine..![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
-;ZAYED;-
-;ZAYED;-
#60
Calipers get delivered tomorrow so I can check.
I thought 2009 E63 would be same as 2009 CLS63... Is there a part number for the shoes to be replaced?
#61
Before gets brake shoes, just try your exist shoes, it may fit..?!?,
if not, then you can get "W219" shoes,
"W219" brake shoes #: "230 420 03 20",
can't assure to you about hole pattern measurement bro.,
06-10 "W219 Cls63 & 07-09 "W211 E63" comes with differ Rear spindle & caliper bolt hole pattern,,
(75mm) or (90mm), depends to the M/Y spec..!
-;ZAYED;-
-;ZAYED;-
#64
-;ZAYED;-
-;ZAYED;-
#66
harryTAM (06-26-2018)
#74
Yeah sure, in case if your "W218" Rear caliper got the same bolt pattern with "W219" caliper,,
as told;-
06-10 "W219 Cls63 & 07-09 "W211 E63" comes with two options of Rear spindle & caliper bolt hole pattern,,
(75mm) or (90mm)..!
-;ZAYED;-
as told;-
(75mm) or (90mm)..!
-;ZAYED;-
