Oil change question.
Also saw where dipstick was in the back driver's side, and looks like the transmission fluid stick, but isn't. This isn't where most pictures show it, but the fine print says it might be in the back. Also, when I bought the filters, it said it worked for "some" M278 motors. Sneaky *******s.
Yes, it took all 8.5 quarts. I used the suck-it-out-through-the-dipstick-holder method. Engine needs to be warmed up to allow the fluid to flow easily.
Also, this was my wife's car and I noticed it said "check engine oil at next fuel stop" or some such. Do you know what that means? It means if you change the oil right then, you will find out you are down 3 QUARTS!
I pulled 5.5 out and put 8.5 in. And yes, the dip stick was dry as a bone.
It's a damn good thing these things have such huge oil capacity. The car only has 30K miles, and we've only owned it for 7K of those. I PRESUMED the MB dealer that sold it to us had changed the oil. Lesson learned.
Good luck.
Good luck.
You tend to forget that German cars consume oil, moreover turbocharged. I got the same light pretty much right before my oil change, and it took less than a quart to bring it to half mark on the dipstick. What the issue might be is that the oil volume the dealer added brings it to the middle level, which might not be enough for the entire 10k miles or so. Of course it depends on the driving style, but was at first to me to see "check oil level" in the morning before going to work
Regards
FCP Euro has them for a great price. I run 5w40 Amsoil but I will be switching to Valvoline 5w40 Euro 229.5 at the next oil change.
https://www.fcpeuro.com/products/mer...des-1761800800
