Adventures in Airmatic
Yep, leaking rear air springs...plus moisture in the system. They replaced both rear air springs, the compressor, the compressor air cleaner, and the valve unit. My cost: $0.00. All covered by the warranty. It should be good to go for quite a few years now.
In my particular case the warranty paid off. If nothing went wrong, I’d be out $2500. I never go to casinos, but this seems similar.
It’s nice to see it up where it should be this morning. The service department at my local dealership was great, by the way. I had a problem, they fixed it, I’m happy.
I've had one leaking airbag that would drop every time the car was locked and the other only dropped once when it was left outside in the cold which sounds similar to the OP's issue. I wonder if I have moisture in the system...
The drop on mine was very noticeable:
https://www.dropbox.com/s/kin7mj3xif..._3739.jpg?dl=0
https://www.dropbox.com/s/c24ixfzal0..._3743.jpg?dl=0
This was the other, non-leaking side:
https://www.dropbox.com/s/ybw72qp0e0..._3745.jpg?dl=0
