Heavy metallic knocking sound from Engine
Old Apr 5, 2022 | 09:54 AM
cls5504matic's Avatar
C63 Vert
Originally Posted by Mousa
This is totally correct there is an issue in tgese engine piston all these engine will go bad at some point not far from 200k km. I have this problem at 80k km and mercedes told me i have to change the engine which unfotunalty cost more than the car .
who at mercedes?
i’ve seen many of these cars even tuned at 100k miles. Some over 185k miles. I do think there is likely a limit but i’d guess about 200k miles.
on facebook.com/facebook/groups/tunedmercedes there is a discussion. B. @ eurocharged boston suggested it was due to the turbo manifold design and heat with exhaust. He did not think fuel trim affected it.
He mentioned towing or long periods of hard work. Like pulls up a mountain, 1 mile pull etc. is what he thought caused it.
madness motorsports with the build the most powerful cls 550 thread got fed up with the manifold and turbo placement and did new ones iirc.
Old Aug 5, 2022 | 10:03 PM
Zerocarpileup's Avatar
2008 S63
Im having the same problem with a 2013 ML63, Lower end tick/knock that appears when hot. No loss of power, check engine light or misfires. Have not borescoped it but recent oil change showed no evidence of metal. Is there cases where this issue was caused by anything other than the worse case scenario? Could an exhaust leak or spark plug cause this? Any success stories out there? Also is there a way to swap out the piston/rod before it becomes a total disaster for the cylinder wall? Also shouldn't a knock sensor have gone off by now?
Old Jan 17, 2023 | 09:06 AM
RA053023's Avatar
Originally Posted by number_one_c55
Beautiful, you have nothing to worry about. Very good cars.
I just bought a silent running 2015 CLS500 with 57,000 miles here in sunny Australia, I know this post is from a long time ago but this issue worries me too.
Do you really think I have nothing to worry about too? If so what changes to the bore/piston relationship did mercedes if any do on the later cars?
I had a 2016 GM LS3 in a Holden Caprice - that thing had piston slap at 40,000 miles when cold which would go away at operating temperature...
thanks
