Need Wheel help!! Have never purchased after market wheel before and deciding between
looking to purchase rims for my 2014 CLS and was wondering if i should stick with 19s or if i go with 20s will they cause my tires to wear out faster? I am a serious noob when it comes to wheels and tires so any info is appreciated in this particular circumstance!
20's ALWAYS look better, but 19's will give you a little more sidewall on the tire.
25mm positive offset front.
33mm positive offset rear in 19 or 20.
John
Todd
hows the ride quality/performance on 20s though? any difference compared to the stock 19s?
Just my opinion...
Todd
I can appreciate the idea of keeping the height ratio as the stock 19's but I would prefer to retain the same rolling overall diameter which the 305/25/20 & 255/30/20 match almost perfectly. The 285/30/20 add's 1" to the OAD and is 1/2 pound heavier and the 245/35/20 add's 0.8" to the fronts OAD and is over a pound heavier. Also, a speedometer calibration might be needed.
Just my opinion...
Todd
With 4 matic, you better use same tire have the OAD. Otherwise, try to put up some tire to reduce the UNDER STEER that comes with the car. The speedometer will be change if you put a tire with different OAD in the rear but the front will not affect the speedometer. The closest OAD to the OE on 20" is 295/25/20 or 305/25/20. Both are within 1% OAD compare to the OE.
The car already have serious under steer with the OE tire of 255 front 285 rear Don't put a tire that's even smaller than the OE in front to increase under steer.
but i went with 20x9 5x112 25et in front and 20x10 5x112 33et in the rear for the wheels and 245/35zr20 in the front and 285/30zr20 in the rear in the conti extreme contacts.... rohana rc10 wheel in matte graphite... my car is black so im thinking it will look great with my chrome delete..
John
