battery tender, front or rear?
I've on'y had one other mercedes, that one had the big battery in the rear and small one up front. E63 2009, That one I had the tender on the big one in the rear.
Does anyone know which should be used for a battery tender on the cls? I'm just seeing strange things with the set up on the bigger front battery. Like there's some kind of interrupt at a certain time frame or voltage.
I'll test the rear acc battery in a few days assuming not many people on here and not much traffic.
Anyway. I'm not having problems with the batteries, I just always install one in every car.
I saw lower voltage on the big one in front around 12.5vdc. But no first crank of the day lag. Rear small was always 12.95vdc. I was thinking rear was all acc and shut down supply until it went full quiet after locking the car and going to sleep after a certain time.
I never got volts to read the same at any time.
I'm letting some months go by and see what happens, there will weeks when it doesn't get driven so I'm sure it will let me know all by itself which one does the heavy lifting.
There are way too many things I don't know about this car yet. Big learning curve.
Thanks for the replies.
*but I'm still trying to figure out the real world voltage and charging info on this set up.
