Engine Misfire. A lot of shaking/jerking
I have had engine misfire for a bit now. Diagnosing little by little, but I have found nothing yet. First I thought it is misfiring from one bank, but the shop guy said it's from both sides.
So I checked the coils, they are good. Replaced plugs (one turned out to be broken or lose, whatever the term may be). The misfire is still there, though it has gotten a little less. However, I drove it today and wanted to see what changed...it drives a bit smoother than before in low rpm, feel a little shake/jerks, but when I floored it, past 4krpm, it's misfiring whole lot. The speed barely went up. It's misfiring at high rpm even more now. Last time I ripped it at high rpm for about a minute, the pull was fine. No shaking or jerking. Today, it didn't shake, it just misfired a lot and didn't speed up.
Had a CEL 2 weeks ago and changed an injector. No other lights on or anything...Idk what to do. I even uninstalled the EuroCharged tune I had and put it back to stock numbers untill I can get it fixed.
The mechanic told me to just drive it on a long drive and lets see if CEL comes on, I don't feel comfortable doing that. He said the same thing when he replaced the injector before and I changed the broken plugs, he still saying the same thing to keep driving.
Any other ideas/suggestions on where I should look? It could be the MAF sensor, but there is no CEL on. Someone pls help.
I think it all started with a bad spark plug lol that little piece of **** lol now the O2 is gone.
I hope all is well.
I saw one of your posts and had to reach out.
We have a 2012 cls 550 with 53k miles, and have had rough idling in the mornings when starting, then it eventually warms up and goes away.
The dealer found oil in/on the harness /02 sensors that seems to be coming from the cam sensor.
Does this cause this problem? The car is occasionally hesitant when gassing it, but still have amazing power when accelerating.
I really could use some help, for I am not mechanically inclined. LOL
Thank you in advance.
I don't believe the oil leak, onto the harness plug, would cause that rough idle. Mainly because the idle smooths out when warmed up.
Oil will become less viscous (more fluid) when warm and prevent the idle from smoothing out. In other words, if oil was causing a rough idle when cold, it will cause it when warm, as well.
There are many things that could cause the rough idle when cold. Seeing that you have only 53k miles on your car eliminates many.
Have you had the spark plugs and/or ignition coils replaced?
The O2 sensor harness plug is far away from the cam position sensors. However, one O2 sensor is right below the oil separator (crankcase breather). These will leak oil both outside and in to the engine intake. Another symptom of the leaking oil separator is blue exhaust smoke upon startup.
I assume your check engine light (CEL) is not on? There may be a pending issue that have not triggered the CEL to come on. Especially, since your problem is intermittent.
The early twin turbo V8's had a timing issue that I don't completely understand. The first symptom is an engine rattling noise upon startup. I own a 2009 non-turbo CLS and I am looking for a newer one. That is why I am on this forum.
A good place to start is to go to an auto parts store and ask them to check for codes. Should be a free service. If there are any codes, pending or otherwise, write them down and report back here.
Many thanks for replying.
Understood on the rough idle, but what will this oil issue cause? The dealer said it causes it, but they seem to be guessing, even though there are visible signs of the issue.
I have not changed the ignition coils, but I believe we changed the spark plugs in the past. (Girlfriend's car)
As I am not mechanically inclined, I am curious, can the 02 sensors be cleaned off or once they get oil on them, they must be replaced?
Only the check engine light is on, not CEL at this point.
Their does seem to be a light rattle when cold starting only, but is fine once the car gets into"operational mode."
It is at the dealer waiting for the warranty adjuster to review it. (O2 sensors are not covered, hence the question regarding cleaning it... May be absurd, but learning.)
The diagnostic fault code mentioned "Rich Gas mixture," along with the actual values for all the cylinders operating within their required specifications.
Tks again for the education.
I am learning about the M278 engine also and may be limited as to what I can offer.
Spark plug replacement is due at 80k miles. Just a thought in case you replaced them to eliminate the rough idle.
The element part of the 02 sensors screws into the exhaust pipe on each side (V8, dual exhaust), so, it is not likely oil is getting on the sensor element. If oil is getting into the electrical plug, portion of the 02 sensor, then yes, could cause a problem. But, as I said earlier, this theory does not hold up since your idle smooths out.
The Check Engine Light is the CEL, one and the same.
I would post a separate topic specifically for the issue you are having. MBWorld is a great resource and users will see your subject line and reply.
This post subject is "Engine Misfire. A lot of shaking/jerking". Your subject could be: "Rough Idle at start, smooths out after warmup". Something like that.
I am curious to hear what others have to say/add. It would be helpful to know what codes are causing the check engine light to come on.
The link you added is a link to your Outlook mail. No dealer diagnosis info there.
Rick
Good point
My extended warranty has agreed to cover the harness, computer, and all sensors.
Once they fix it, I will try to post under the actual topic.
I am curious if any other components connected to the harness will be adversely affected.
Tks
I feel the only way other components can be affected by a harness swap, is that the new harness being damaged before the replacement.
Rick H
I was thinking the old harness that is being changed this week could have damaged other components than what they are changing out.
They are changing all 02 sensors, cam sensors,harness, and a computer that are linked to the harness.
I was thinking other components could be damaged as well, or deteriorating and will become an issue. Thoughts?
I also had the EC tune with burble. What I did was that I swapped all my coils from Bank 1 to Bank 2 of the engine...and just by doing that, my car started to run smooth. No shaking/jerking anymore, at all. I think maybe some wiring might've been loose on some coils? No clue at all.
Another thing was that later, it started showing misfire on all cylinders on Bank 1. The mechanic, knowing nothing about these cars and how ECU/OB2 tune works, told me my tune ****ed up my software and I must replace the software, another $1200. What I did was changed the Upstream O2 sensor on Bank 1. Car is back alive. Been a month.
Now, I'd suggest, if you have burble tune with cats on...remove the burble tune. I highly believe that's what shot my O2 sensor and caused all this headache. I'm planning to reflash and remove burble tune from Stage 1 tune and later get Stage 2 w/ burble. then there are no cats and O2 sensors that can be destroyed lol.
At least, that's my story and solution haha.
